Help installing projecters...
I just installed my projecters, but since I suck with wiring...can someone help me and explain to me how to connect the wiring for the halo-rings...
The instructions tell me to connect the black line to the negative of the park signal... but what color is that and where would i splice the line and stuff...HELP!
thanks!
thanks!
there is a brown wire and a black wire going into the smallest bulb, the brown one you cut is the power which you connect all the white wires to, the black one of equal lentgh is the ground(negative) which you connect all the black wires to, do that and youll be fine.
Delta coupe
Sep 30, 2015 08:11 AM
