Help with led tail's!!!
Old Jun 15, 2010 | 09:26 PM
hook's Avatar
Ok so today my led tails came in the mail and they look great but one little flaw the turn signal dose the "light out" fast blink. How can I fix this I was think a resistor. Would one of these work? http://www.radioshack.com/search/ind...=resistor&sr=1
Im not sure How many ohm's or whatever i should use
Old Jun 15, 2010 | 09:30 PM
Brizzal's Avatar
most people just replace the turn signal flasher, usually can find them on ebay
Old Jun 15, 2010 | 09:32 PM
hook's Avatar
Like I dont know how much resistence a factory bulb has. any know?
Will my tail lights still work turn signal and all? and what would i type in to get this on ebay?
Old Jun 15, 2010 | 09:34 PM
Acey's Avatar
http://cgi.ebay.ca/Load-Resistors-LE...item335dfe1c27
That's it that's all!
Old Jun 15, 2010 | 09:35 PM
RecklessL61's Avatar
subd for anwser on flasher i have same problem and am to lazy to install a resistor
Old Jun 15, 2010 | 09:39 PM
TommyP's Avatar
AWD > FWD
Look at the headlight and tail light thread, and buy the resistors under the switchbacks. They will work perfectly.
Old Jun 15, 2010 | 09:40 PM
Acey's Avatar
I get the feeling we don't have a flasher in our cars, it's computer controlled. Hence the signal clicking sound coming from your BCM through the driver's side speaker.
Old Jun 15, 2010 | 09:42 PM
hook's Avatar
Yeah But it works fine with factory buld and no lights are out^^^ so it must have one
Old Jun 15, 2010 | 09:43 PM
Bluelightning's Avatar
Got Bewst?
I bought a ket off Ebay from K2 motors about a month ago. Had the same problem. There is no fix other than putting in resistors. Too lazy to put them in? It takes 5 minuites. You don't even need to cut anything. Here what i got and it worked perfect. It comes with scotch locks so it just taps into you're harness. No cutting. Like i said took all of 5 min to install. No more fast blinker problem.
http://www.v-leds.com/BlinkerWarning...-p4783296.html
Old Jun 15, 2010 | 09:44 PM
TommyP's Avatar
AWD > FWD
No, there is no flasher in our cars. They are computer controlled. That's why you need the resistors. A new flasher may work on other cars, but not on this. The reason they flash fast is that LEDs, even a bunch of them, draw less power than the factory bulbs do, and it makes the BCM think the bulb is burned out, and flashed it fast to tell you the bulb is burned out, even though the bulb is clearly there. It is reading current readings.
^^^ that's exactly what you need and what I linked to in the headlight and tail light thread.
Old Jun 15, 2010 | 09:47 PM
hook's Avatar
Has anyone tryed these? how good do they work? and is 25 watts good for a cobalt?
so this is the right one for my bolt i suppose. and they still work good for your car? how long have you had these?
Old Jun 15, 2010 | 09:48 PM
Acey's Avatar
It works fine, I know because I bought them ages ago. I think people aren't listening to me because I have 100 posts but I assure you I've been here for a while and know what I'm talking about.
Old Jun 15, 2010 | 09:50 PM
Got Bewst?
Yup it's what you need. Like it says it pulls the same resistance as a 2 filiment bulb. If you don't get the right resistance it won't work and these worked great. I've had them on my car for about a month
Old Jun 15, 2010 | 09:54 PM
Scythe_Snake's Avatar
subbed for good resistors. been too lazy to buy them until now =)
Old Jun 15, 2010 | 10:14 PM
Got Bewst?
Snake get those ones from v leds. It comes with everything you need including scotch locks to tap into you're harness and they are anodized gold. Bling haha. I actually have a spare kit because i thought when you order 1 it was one resistor but it's actually 1 kit lol
Old Jun 15, 2010 | 10:20 PM
NCC-2000's Avatar
I've had the set from V-LEDs installed for my front signals for ages and they work perfect. My LED tails actually came with a resistor system built in so I didn't have to worry about the back, but I guess not all tail light manufacturers think ahead.
Old Jun 15, 2010 | 10:28 PM
hook's Avatar
Yeah i suppose not. oh well ordered resistors just now 12 bucks not to bad
Old Jun 15, 2010 | 10:29 PM
Way ahead of you man. The second you posted them up I ordered them
Old Jun 15, 2010 | 10:50 PM
Got Bewst?
Haha good stuff
How to Guide
57
Oct 15, 2015 11:56 AM
Cptnslo
Sep 24, 2015 09:32 AM
dieGone
Sep 23, 2015 10:20 AM
jonnycat
Sep 19, 2015 12:58 PM
