HID Fog light help. Please.
I know someone on here had this exact same problem but never saw a solution. I am installing my DDM HID fog kit and need to know if I am doing this correct.
I looked for some diagrams on DDM, BuyHIDs, etc but found nothing for H11 fogs on a Cobalt.
The relay harness is already routed in the car but now I need to hook up the ballast, stock harness, and bulbs.
Here is the plug/wire in question.
Here is the relay harness. The two plugs for the drivers side.
Stock harness plug which went to the stock fog light.
Now this is how I assume it goes. Stock harness and the new plug/cable. I have the black and blue prongs matched up with the black and blue wires from the stock harness.
Now I plugged the new plug/cable into the matching end of the relay harness.
I am planning on plugging the other plug from the relay harness into the ballast.
Then match these plugs from the ballast up to the plugs from the new HID bulb.
If anything is incorrect please let me know. I still have to get some VHB tape for the ballasts but am planning on plugging everything up later today.
z28addiction
Sep 28, 2015 12:03 AM
, what color HIDs did you go on the fogs?
