HID fogs
i mounted mine with a strip of steel under the headlight bracket. ummm, its kinda hard to explain lemme make a quick paintshop
there we go... the strip of steel is underneath the bracket kinda towards the front of it. understand? and the screw goes thru the top of the headlight bracket and thru a hole i drilled in the little steel strip. well actually its a bolt with a nut but u get it right? HTH
sweet might try that^ sounds easier.
but as of now I have the 2 male wires coming from the bulb (black and blue) and do not know where they connect to.
not the exact kit, i just have the plug and play, no relay.
bump ganna take a dump
bump 92 views.....
bump 92 views.....
