HID fogs
Old Feb 1, 2010 | 04:44 PM
BumbleBee's Avatar
HID fogs
would like to see some setups and how you mounted your ballasts.
Old Feb 1, 2010 | 05:13 PM
chitala383's Avatar
i mounted mine with a strip of steel under the headlight bracket. ummm, its kinda hard to explain lemme make a quick paintshop
there we go... the strip of steel is underneath the bracket kinda towards the front of it. understand? and the screw goes thru the top of the headlight bracket and thru a hole i drilled in the little steel strip. well actually its a bolt with a nut but u get it right? HTH
Old Feb 1, 2010 | 10:07 PM
BumbleBee's Avatar
Awesome, that helps a lot.
Old Feb 2, 2010 | 07:29 AM
BLK08SS/TC's Avatar
The HID's that I ordered had a lot of wire to connect to the fogs, so I used industrial strength velcro to mount the ballast under the headlight bracket.
Old Feb 2, 2010 | 08:28 PM
BumbleBee's Avatar
sweet might try that^ sounds easier.
but as of now I have the 2 male wires coming from the bulb (black and blue) and do not know where they connect to.
not the exact kit, i just have the plug and play, no relay.
bump ganna take a dump
bump 92 views.....
Old Feb 3, 2010 | 02:41 AM
BumbleBee's Avatar
bump need help
Old Feb 3, 2010 | 02:46 AM
HB_SS/TC's Avatar
those plug into the factory harness
Old Feb 3, 2010 | 03:40 AM
post pics of everything once you get it all installed
Old Feb 3, 2010 | 03:51 PM
BumbleBee's Avatar
I will so that no one has the issues im going through lol, but im waiting on a nice day out.
Old Feb 3, 2010 | 10:04 PM
sounds like a plan. i dunno how long youll have to wait in ohio never been there, what about a friend with a heated garage?
Old Feb 3, 2010 | 10:29 PM
BumbleBee's Avatar
HAHA, dont think there is one in 100 square miles of me.
Old Feb 4, 2010 | 12:58 AM
G11's Avatar
G11
i mounted mine to the side of the plastic under headlights. made sure that it was secure and check every once in a while and still holding strong
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
fflores
Sep 6, 2005 07:31 PM
