HID Help
Old Jun 20, 2011 | 04:22 PM
cobythecobalt's Avatar
Question HID Help
I searched but couldn't find anything relivant! I'm looking into buying an HID kit, so I was wondering if I need to get a relay kit or can I do without it? I have an 09 balt. Will it affect the DRL or what...?
Old Jun 20, 2011 | 05:13 PM
Quick92RS's Avatar
Most HID kits come with the relay harness. Yes you should use it. Pull the fuse for DRL's.
Old Jun 20, 2011 | 07:11 PM
DaBuzzard's Avatar
^^^ x2 - Use a relay harness if you value your stock wiring, and pull the DRL fuse if you value your ballasts
Old Jun 20, 2011 | 07:20 PM
mkulrey13's Avatar
What they said. Relays we recommend to everyone.
Old Jun 20, 2011 | 10:50 PM
keiserX13's Avatar
First step in the HID install is to pull the DRL so it doest cause problems
Relay harnesses are not need but are Highly Recommended to protect your factoryy wiring and the bulbs/ballasts
Old Jun 20, 2011 | 10:52 PM
BlackARCA06's Avatar
I ran without a relay for 6 months, never doing that again. Get a relay and pull your DRL fuse.
Old Jun 20, 2011 | 10:53 PM
Hammbones's Avatar
DRL Fuse + Wiring Harness = One light not lighting up or what exactly happens?
Old Jun 20, 2011 | 11:08 PM
Gixxercobaltdriver's Avatar
Yeah I am completely with you. I never had a problem with out running a relay harness for a good year and a half. The only reason why I did finally upgrade was because over time they start to get harder to ignite, which the stock wiring has a hard time doing, and then you get one or both bulbs not being able to start up correctly. The relay harness will fix that issue by supplying battery voltage all the time.. I did my relay more for a preventive maintenance.. but hey my bulbs went out after a week of having the relays.. switched the bulbs and ballasts with BUYHIDS... and bam all better.
Oh and still havent pulled the DRL fuse. I have a habit of just flicking the switch to off when driving in the day so the bulbs dont ignite at all when I start the car... to me Id rather just keep the fuse and actually lift my hand and use it instead of being lazy and not having DRLs all the time. I like it when at night I drop the ebrake and my lights kick on.
Old Jun 30, 2011 | 09:05 PM
BeradSS's Avatar
So should have read this thread a week ago, i have 8k's comming from ddm w/o a relay. another delay...i have a headlight out as it is and need to get these in.
Old Jun 30, 2011 | 09:18 PM
DBlock's Avatar
QUEEF-NUGGETS
FML,I just order my hids but didnt get the relay
Old Jun 30, 2011 | 09:48 PM
BeradSS's Avatar
Dblock ive been doing some research i think we can make our own relays pretty cheap. How i do not know
Old Jun 30, 2011 | 09:53 PM
DBlock's Avatar
QUEEF-NUGGETS
Well i had hids before but got rid of them.beacuse the driver side hid would always turn on for a split second and than turn off,and blow the fuse.
Old Jun 30, 2011 | 09:54 PM
BeradSS's Avatar
which kit was that? was there a relay?
Old Jun 30, 2011 | 09:56 PM
DBlock's Avatar
QUEEF-NUGGETS
Not sure,they were from ddmtuning. On my old ss/tc it.never.did it but i bought the one i have now used so maybe some wiring is messed up...werid thing is the stock lights work lol
Old Jul 1, 2011 | 02:58 AM
ronn's Avatar
Originally Posted by Gixxercobaltdriver
Oh and still havent pulled the DRL fuse. I have a habit of just flicking the switch to off when driving in the day so the bulbs dont ignite at all when I start the car ... to me Id rather just keep the fuse and actually lift my hand and use it instead of being lazy and not having DRLs all the time. I like it when at night I drop the ebrake and my lights kick on.
I start my car in underground parking where it's relatively dark. I take it that I can't start the car without the lights comming on at first ? I turn mine off after start up (no HIDS yet). I take it there's no way to prevent this without pulling the DRL fuse?
"I like it when at night I drop the ebrake and my lights kick on"
SO........correct me if I'm wrong....
I don't think you have a choice on having em turn on when it's dark...e brake has nothing to do with it.
Old Jul 1, 2011 | 04:08 AM
Quick92RS's Avatar
Using your own relays isn't that big of an issue. You can get them at radioshack pretty cheaply and you only need one. As far as whose HID kit it is, it doesn't really make that much of a difference unless you're going between analog and digital ballasts. They're all pretty much the same kit. If you need help on wiring your own relays, just ask.
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
juandirtymessican
Oct 27, 2012 10:41 PM
