HID Help
Old Apr 2, 2013 | 07:36 PM
pudge12's Avatar
HID Help
I have a 2006 LS. A friend gave me an HID kit as a present a few months back, but the driver side light is out. All I know about the kit is that its plug and play. After some inspection, I noticed that the passenger side is making a noise, but the driver side isn't. From some reading and searching (correct me if I'm wrong) I found that I was suppose to install some sort of relay with the kit. I think the ballast is dead, but I'm not sure how to find a replacement. Also, what is it that I need to prevent this from happening again. Is there an easy fix? I removed the ballast if a picture of that would help, I can upload it. Thanks for the help.
Old Apr 2, 2013 | 07:42 PM
Wert842's Avatar
The relay just allows you to take full advantage of the hi/beam feature and to keep from dimming and flickering. Ballasts die. It happens all the time. Just get a new one to replace it. Put the ballast somewhere were the weather and conditions can't really effect it.
Old Apr 2, 2013 | 07:47 PM
pudge12's Avatar
I've never had high beams once they were installed. Are all ballasts the same, or is there something I need to know to order a new one? Do you know anything about the relay, or is it not necessary? Thanks
Old Apr 2, 2013 | 07:51 PM
kcg795's Avatar
Junk the kit. Do a retrofit.
Old Apr 2, 2013 | 07:52 PM
Wert842's Avatar
GEt a new ballast off ebay or something. They're like $20 for 2 new ones. no biggie. If you didn't have high beams, then you don't neccesarily need a harness.
YA sounds intelligent.
pudge12's Avatar
Not quite sure what you mean by that? I at least need to get the light up and running so I can stop getting pulled over for having a light out. Then I can do something better.
Old Apr 2, 2013 | 07:53 PM
574's Avatar
574
Retrofits still have ballasts..
Old Apr 2, 2013 | 07:55 PM
Wert842's Avatar
More than likely you're gonna have to put your old lights back in and order another ballast. Simple as that.
Old Apr 2, 2013 | 08:00 PM
pudge12's Avatar
Yeah, I didn't understand what he meant by that. Thanks for the help.
How often do you find these things go out? Is it extremely common? I would find it annoying if I had to keep spending money to keep them up more often then bulbs. jw and thanks again.
Old Apr 2, 2013 | 08:02 PM
Wert842's Avatar
Its kind of random. I bought a kit off ddmtuning and the ballast went out like a couple days after having it installed and I've also bought a kit off ebay for my old g6 and I to this day after 4 years have the bulbs and ballasts still working. It's basically hit or miss.
Old Apr 2, 2013 | 08:04 PM
pudge12's Avatar
Sounds good, I'll order one up and hopefully will have it soon. I've been pulled over a few times already, but been too busy to figure this out. Glad its an easy fix.
Old Apr 2, 2013 | 08:05 PM
574's Avatar
574
Put in stock bulbs if you have to for now
Old Apr 2, 2013 | 08:08 PM
pudge12's Avatar
I think I no longer have the part that holds the original bulb. So I'll be going one eyed for the time being.
Old Apr 2, 2013 | 08:11 PM
Wert842's Avatar
Lol. You dont have the parts that hold the bulb? What did you do with them and how are your bulbs staying in then??
Old Apr 2, 2013 | 08:13 PM
joezombies's Avatar
what part would that be? what kind of headlight housings do you have?
Old Apr 2, 2013 | 08:54 PM
kcg795's Avatar
Yeah, and sticking HIDs in a halogen fixture sounds intelligent also, especially a low beam only kit.
Old Apr 2, 2013 | 08:57 PM
Wert842's Avatar
You told him to do a retro kit and he is asking question about basic hid kits. Honestly, come on... Hids in a halogen fixture is everywhere now a days. You'll have that. It's no biggie. move on.
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
juandirtymessican
Oct 27, 2012 10:41 PM
