HID Kits help
Old Nov 7, 2007 | 01:21 PM
rcmpayne's Avatar
HID Kits help
I am ready to make an order for HID conversion kit but had a few questions, what Kelvin Temperature should I go with? Also the fog lights are H11's so could I get a kit for them too?
2006 Pontiac G5 GT
Stock headlights
Stock Fog lights
Old Nov 7, 2007 | 01:59 PM
07 SS/SC's Avatar
You can get a HID kit for the H11's no problem.
What temp you get is up to you. 4200-5200 is more white, then above that you start to get more blue ish. Once you get above 7000ish you will start to get a purple color. 4200 has the best light output meaning it will light the road up the best. The higher you go the less effective the output is.
Good luck!
Old Nov 7, 2007 | 04:19 PM
rcmpayne's Avatar
Even if I go with a bluish it will be better then reg bulbs still correct?
What do people go with the better visibility or nicer look?
thinking of getting these
http://cgi.ebay.com/ebaymotors/XENON...QQcmdZViewItem
Old Nov 7, 2007 | 05:20 PM
kyssmySS's Avatar
8k all the way.
Old Nov 7, 2007 | 07:00 PM
HunterKiller89's Avatar
i have 10k lows (these are blue, but border the purple area...im sure 12k would be blue/purple)
and 6k highs (these are white...if im using brights, then i need the best output possible)
the 10ks are still MUCH better than halogen bulbs, and the 6ks are slightly better than that.
Old Nov 7, 2007 | 07:18 PM
TheCaptain's Avatar
If you don't have projectors to put HIDs in, don't get the HIDs, because you'll blind the crap out of everyone else, and most HID kits are only SINGLE BEAM. (ie: stock headlight bulb is dual beam, single bulb.) If you put a HID kit that just is single beam in a stock housing, your highbeam is now gone.
And you don't need HIDs in your fog lights, unless they are just for show, because fog lights arn't supposed to be bright. (Hence why you don't drive around with the highs on in the fog.) Another point, many H11 HID kits are also too long for our fog light assembly,though a slim ballast HID may fit...
Here's a dusk photo of my car with Onex's 6000K HID kit, in projectors. If thats any help.
Old Nov 7, 2007 | 07:25 PM
rcmpayne's Avatar
I thought our cars only had one bulb with a high/low on them?
edit nvm thecaptain answered this one
an0malous's Avatar
4300 is the best lighting output by the books... but is the boring yellow/white of a halogen
6k has IMO equal lighting performance as 4300, but a much nicer ultrawhite color
8k is my favorite color wise, beautiful blue, slightly less lighting than 6k
10k is a little to purpleish for my taste, and the lighting is barely better than a good halogen
how do I know? i have them all
Old Nov 7, 2007 | 07:38 PM
steddy2112's Avatar
I had to take mine out of the stock housings because the PO PO didn't like it too much...but go with 8k for the best balance between blue-ness and light output...but stay away from anything higher than that, and try not to put them in the stock housings...
Old Nov 7, 2007 | 07:39 PM
an0malous's Avatar
^^ X 14598726345
Old Nov 7, 2007 | 08:21 PM
rcmpayne's Avatar
So if I order the HALO LED PROJECTOR do I get two sets of 9007 HID conversion kits for the 2 high and 2 low beam?
Old Nov 7, 2007 | 08:23 PM
an0malous's Avatar
ebay projectors use H1 bulbs. not 9007
and HIDs in the highbeams would be a waste IMO.
the highbeam on the ebay projectors are insanely good even with the **** bulb they come with.
save yourself the cash and just get the H1 HID for the lowbeam, and a nice set of bulbs for the highs (also H1)
Old Nov 7, 2007 | 08:24 PM
steddy2112's Avatar
Two sets of H1s
Try not to go with high beam HID because flashing HIDs are bad for them and you tend to flash your high beams(to signal people and so forth)
Beat me, ******ian guys all fast and ****
Old Nov 7, 2007 | 11:31 PM
Silv3r's Avatar
Can anyone post pics with the 6000k and then the 8000k? I'm interested to see the diff between the two side by side
Old Nov 7, 2007 | 11:34 PM
TheCaptain's Avatar
My 6000K is above ^^^
Old Nov 7, 2007 | 11:49 PM
effex80's Avatar
woah. I just put some onex 8k's in my stock housings. How whould just changing the housing make it so you have high beams? isnt that all about the bulb?
Old Nov 7, 2007 | 11:52 PM
TheCaptain's Avatar
Yes, but if the housing has two bulbs, then you now have a seperate low and high beams. An HID low and halogen high. All the housing does, is split the beam back into two. (or one, depends what housing you have)
Old Nov 7, 2007 | 11:55 PM
Coblt ss super's Avatar
im getting rid of mine to get the famous 20K that some people round here got, which is a deep deep dark blue and i want it!!! haha, you should get i think its 30K that is like green
Old Nov 7, 2007 | 11:56 PM
an0malous's Avatar
laff.
Old Nov 7, 2007 | 11:59 PM
TheCaptain's Avatar
Hey, if he never leaves the city, it should be alright...
Off topic: effex80, clean out some of your pms, so i can pm you...
Old Nov 8, 2007 | 05:32 AM
EmperorJJ1's Avatar
And you don't need HIDs in your fog lights, unless they are just for show, because fog lights arn't supposed to be bright. (Hence why you don't drive around with the highs on in the fog.) Another point, many H11 HID kits are also too long for our fog light assembly, unless you get a shorty HID, or slim etc...
where can i find shorter hids? i didnt know they existed
Old Nov 8, 2007 | 11:09 AM
07 SS/SC's Avatar
20K is NOT blue, and have fun not seeing ****. You are going to have deep purple headlights.
Old Nov 8, 2007 | 12:39 PM
TheCaptain's Avatar
Haha, my bad. They don't exist. Just slim ballast HIDs. I'll fix that.
Here's another post with slim ballasts, and a colour chart in it too.
https://www.cobaltss.net/forums/show...light=slim+hid
And i just noticed, that ebay site, does have high/low halogen/HID bulbs. And high/low HID bulbs. So the dual beam hids should work, but please, for the love of cars, get projectors!
Old Nov 9, 2007 | 04:00 AM
EmperorJJ1's Avatar
i have projectors but one of my low beams went out... so i figure might as well go with hid so i dont waste money on some more bulbs. but damn getting me to buy them is the problem. I sorta want to get the McCulloch kit since i herd they are the best but i cant bring myself to do it
Old May 21, 2008 | 09:08 PM
ViSiONZ's Avatar
Anyone wanna help me out? Its regarding H11 HID's also. Here's the thread.
https://www.cobaltss.net/forums/appearance-48/questions-regarding-hids-foglight-projectors-113228/
