HID kits from vendor 'operatic'
Old Jun 4, 2008 | 09:31 PM
Panici's Avatar
HID kits from vendor 'operatic' (3bspec.com)
Hey guys, has anyone installed their kits from the vendor on there 'operatic'?
How do you like them? Any problems? Pictures?
I'm thinking of ordering a 50w 6000K H11 kit for my fogs, to compliment my lowbeam silverstars.
Where did you guys mount the ballasts for the fogs?
---EDIT---
Well I just ordered a set. 50w 6000K H11 kit
I'll post up some pics when I get it installed
Old Jun 5, 2008 | 09:45 AM
LS6Rally's Avatar
interested in the same kit, just not sure of the wattage for the ballast i wanna pick. what is the main Diff??
Old Jun 5, 2008 | 11:10 AM
stevenb's Avatar
i bought them, have mine on now and i like them (8k) sorry no pics
good people too.
Old Jun 5, 2008 | 05:53 PM
Panici's Avatar
The main difference is brightness.
35w ballasts have been used forever, so it's probably the most common. 50w are relatively new.
The harness this kit has IS a relay harness, so there will be much LESS load on the OEM harness then with regular halogen bulbs.
Old Jun 6, 2008 | 08:34 PM
operatic's Avatar
I know theres a few people on here that I've met up with locally and even installed their HIDs for them, I just need for them to chime in
Old Jun 7, 2008 | 01:08 PM
Panici's Avatar
Where did you mount the ballasts for the fogs?
Also do i have to remove the airbox on the passenger side (and both headlights) to get at the fog lens? Or can I get at the fogs from underneath?
Old Jun 11, 2008 | 10:13 PM
operatic's Avatar
Yes I have. I mounted them below the headlight. When you take out the headlight and then take off that plastic piece, there is a spot for the ballast that is perfect.
As for the fog lights, I was able to just roll the car up on ramps and get it from underneath
Old Jun 11, 2008 | 10:31 PM
LS6Rally's Avatar
how much for an install? i live near by
Old Jun 12, 2008 | 02:22 PM
operatic's Avatar
Sent you a PM
Old Jun 12, 2008 | 07:20 PM
06blackSC's Avatar
These kits are real nice. I have two of his kits in my car and they work awesome. I mounted my ballasts under the headlight buckets. Also, i was able to reach my fog light bulbs with the headlights and headlight brackets removed. Otherwise you will have to get under the car and remove a splash panel to get the bulbs out. I also live real close to the vendor. He has been nothing but incredible as far as customer service goes.
Old Jun 12, 2008 | 09:28 PM
operatic's Avatar
Nothing like working on your projectors to make the cut off line smoother right
Old Sep 11, 2008 | 04:15 PM
ViSiONZ's Avatar
Take out the 4 screws then take off the black plastic head light bracket & mount them underneath it like you see in the pic
Those are my head light and fog light ballasts.
Just feed the wires through where you think it will all work out for you. Also, I didn't drill holes into my car to mount them, I used industrial strength adhesive velcro & it hasn't failed me yet after months of use! lol.
Old Sep 11, 2008 | 04:21 PM
wardzach2007's Avatar
H.i.d.'s Are One Of The Easiest Mod's You Can Do To Your Car.
dennis69
Oct 20, 2015 04:49 PM
thewafflesareburnt
Sep 30, 2015 02:29 AM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
