HID Lights
Old Jan 1, 2014 | 10:28 PM
MVPKiLLA's Avatar
Exclamation HID Lights
Hello all,
Has anyone purchased these hid lights from zzp?
ZZPerformance - Premium Canbus HID Conversion Kit #ZZ-PCHID
if so, did you have any problems installing with a relay harness? also, did you use both "control wires" that comes with that kit?
so much for an easy install.... lmao i wish i was more electronically savvy
anyways please let me know! feedback will be greatly appreciated
Old Jan 1, 2014 | 10:46 PM
What headlights are you installing these in? I'd just go to the Retrofit source for HID goodies.
Old Jan 1, 2014 | 10:49 PM
MVPKiLLA's Avatar
im just installing these in my stock headlights.. id love to go to the retrofit butt its expensive so just went with the hid goodies for the stock lights for now.
Old Jan 1, 2014 | 10:57 PM
qwank's Avatar
a chinese hid is a chinese hid. just buy these, lifetime warranty:
https://www.ddmtuning.com/
Old Jan 1, 2014 | 11:03 PM
SalvageBaltSS's Avatar
If your putting them in stock headlights, aim them down.
Old Jan 1, 2014 | 11:06 PM
MVPKiLLA's Avatar
to aim them down do you just have to mess with the bulb when putting it in the stock headlight?
Old Jan 1, 2014 | 11:11 PM
qwank's Avatar
no there's an adjustment nut on the head light that you turn. you only need about a turn to a turn and a half down.
an easy way to do it is measure 10 ft from your garage door or a similar wall to your headlights. measure from the ground to your headlight, use the hot spot on the tape measure, then measure the wall. the hot spot on the wall should be 2'' lower legally.
with HIDs I put them 3'' lower.
Old Jan 1, 2014 | 11:12 PM
On the top of your headlights you have a adjustment screw. Park your car on a flat area. Point your car towards a garage, them aim them down.
Old Jan 1, 2014 | 11:13 PM
MVPKiLLA's Avatar
ahhhhh didn't notice the little adjustment nut. but thanks! will make sure to do that.
Old Jan 1, 2014 | 11:19 PM
MVPKiLLA's Avatar
ahh ok ok thanks didn't notice it.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
