HID Lights
Hello all,
Has anyone purchased these hid lights from zzp?
ZZPerformance - Premium Canbus HID Conversion Kit #ZZ-PCHID
if so, did you have any problems installing with a relay harness? also, did you use both "control wires" that comes with that kit?
so much for an easy install.... lmao i wish i was more electronically savvy
anyways please let me know! feedback will be greatly appreciated
an easy way to do it is measure 10 ft from your garage door or a similar wall to your headlights. measure from the ground to your headlight, use the hot spot on the tape measure, then measure the wall. the hot spot on the wall should be 2'' lower legally.
with HIDs I put them 3'' lower.
no there's an adjustment nut on the head light that you turn. you only need about a turn to a turn and a half down.
z28addiction
Sep 28, 2015 12:03 AM
