HID only working when cold outside?
Old Sep 11, 2012 | 02:34 AM
Kyle09TC's Avatar
Well for the last couple weeks I has been driving with 1 HiD but now that the temperature has dropped at night as I live in Canada they have both been working only when it's below 10 degrees ish. Any idea what the problem could be? I have a new ballast on the way but I'm wondering if its not the ballast. I have G3 retros If that makes a difference
Old Sep 11, 2012 | 10:17 AM
CCBalla10's Avatar
make sure you check the grounds for the HID's, do you have a relay?
Old Sep 11, 2012 | 10:41 AM
1AJeremyD's Avatar
Sounds like a short some place. When its cold out everything shrinks. Sounds like it might be the bulb or possibly an issue with the ballast. Swap out the ballast and see if that fixes the problem.
Old Sep 11, 2012 | 02:46 PM
Kyle09TC's Avatar
The bulb works on the other side so that's why I thought it was the ballast. I will check the ground and see it that makes a difference
Old Sep 11, 2012 | 07:46 PM
Kyle09TC's Avatar
I moved the ground and it works again. Thanks alot for the help
Old Sep 11, 2012 | 08:14 PM
BlackLsCoupe's Avatar
dam im late. was going to say sounds like bad ground
Old Sep 11, 2012 | 11:50 PM
Kyle09TC's Avatar
At least you knew what it was! I hate wiring!
Old Sep 12, 2012 | 06:38 PM
yea im good at it. comes natural to me. wired my whole house with my dad saved us thousands
Old Sep 17, 2012 | 02:42 PM
Kyle09TC's Avatar
Well it worked for 2 days and now I went out and sanded the area under the fender bolt to make sure it had a good ground and still nothing? But still works when it's cold. Each side has their own relay and the passenger one works all the time. Any ideas?
Old Sep 17, 2012 | 02:58 PM
mkulrey13's Avatar
Assuming your running your G3 retros its the harness. There notorious for failing because they get wet.
Old Sep 17, 2012 | 07:37 PM
Kyle09TC's Avatar
Oh great. That's what I didn't want to hear. I guess I will have to get another one sent from china... 30 days later I might get it..
Old Sep 18, 2012 | 08:26 AM
mkulrey13's Avatar
Depending on the style harness you have. The OLd school 9007 Bi-Xenon harness from TRS may work. Shoot Matt@theretrofitsource.com an email and say mike sent ya to see if they had any orginal 9007 Bi-Xenon harness's.
Old Sep 18, 2012 | 09:11 AM
turbosmart4's Avatar
Fk I think imma need a harness then too...............
Old Sep 18, 2012 | 04:38 PM
low_k3y's Avatar
You swap bulb sides to confirm not bulb? I know shot in dark my kit 1 month after I had it did it couple times. 5 months later bulbs crap and works when it wants to just got a quote from mike on a bulb... Hope that's 2 but I have my doubts :p
Old Sep 18, 2012 | 07:49 PM
Kyle09TC's Avatar
Yeah I have a spare bulb that I used on the passenger side and it worked and then hooked it up on the drivers side and nothing. Wish this happened before I would of bought some mini H1s from the hid sale and started building my original ones.
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
roth
Sep 26, 2015 12:16 PM
OrangeCoba
Sep 25, 2015 06:06 PM
