HID question
i mean like the first two weeks of havig them in they were the same color blue. but i took my lights out to check and see if the ballast were still mounted and then put it back together and i turnt them on today and the passanger side was not near as blue as the drivers
Sounds like maybe a bad bulb? Did you try swapping the bulb across the car to see if the issue follows the bulb? If it does it's the bulb, if it stays on one side swap the ballasts and see if it follows the ballast.
Iceberg
Sep 29, 2015 12:33 PM
