Hid relay question
Old Jan 23, 2012 | 10:38 PM
Blinker fluid's Avatar
Hid relay question
I was reading through the "hid-what to know before you buy" and noticed he stating you need a relay to run off your 35w hid kit. I have kits for heads and fogs that I have not put in yet, but will they be fine without a relay? Anyone doing this? Thanks!
Old Jan 23, 2012 | 10:40 PM
keiserX13's Avatar
yes they are fine without
but its recommended to use them
Old Jan 23, 2012 | 10:43 PM
The fuse will pop before anything happens to my wiring right?
Old Jan 23, 2012 | 10:55 PM
chitala383's Avatar
It should, that's the point of a fuse. I definitely suggest using a relay though. It's simple to wire up and def worth it.
Old Jan 23, 2012 | 10:59 PM
Ok thanks, until I get around to buying them, I just want to know that my hids will run safely without relays
Old Jan 23, 2012 | 11:24 PM
Validater's Avatar
make sure you either a. mount the relay upright and in a position not to get wet. Thats what I've done and its been good for almost 2 years, or b. get a waterproof relay which has rubber seals and mount it upright and in a position not to get wet, I wired my friends car and didn't follow those rules with the first 2 relays. Needless to say they rusted and failed.
Old Jan 24, 2012 | 12:52 AM
AndrewSS/TC's Avatar
Depending on the HID kit you have you could have some issues powering them without a relay, like I do. They take multiple tries to come on and will go off periodically.
Old Jan 24, 2012 | 04:44 AM
LaserBlueCobaltSS's Avatar
Put relays on them man its worth it.
And its really easy to hook up!
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
