HID Woes...elp?
Old Apr 30, 2007 | 05:01 PM
tiny's Avatar
HID Woes...elp?
So I took out my HID bulbs and reverted back to stock bulbs and wiring for the winter, but I left my ballasts and ignitors mounted in the engine bay. They weren't low to the ground, they were mounted right below the headlight cradle. Earlier this week, I went to reinstall the bulbs, and I realized the driver side doesn't work. I checked the bulbs on the passenger side, and they both work.
So, how do I test the ignitor/ballast?? Should I just buy a whole new kit?
Old Apr 30, 2007 | 05:04 PM
mkulrey13's Avatar
why would you remove for the winter?
Old Apr 30, 2007 | 06:17 PM
tiny's Avatar
1. I didn't know if it was bad for the bulbs
2. I needed to take them out to pass inspection
Old Apr 30, 2007 | 06:34 PM
DaREDss's Avatar
mine arent plug and play where do i wire the ground
Old Apr 30, 2007 | 06:47 PM
mkulrey13's Avatar
anyplace theres a ground connection..
Old Apr 30, 2007 | 06:52 PM
yellowcobaltss05's Avatar
anything that is metal DEE DEE
Old Apr 30, 2007 | 07:38 PM
oldsskool's Avatar
There is a ground right behind the drivers side headlight.. you will see a bolt in the framing area right behind the light... there is something grounded to it already, just loosen that bolt and toss your ground in with the other
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
juandirtymessican
Oct 27, 2012 10:41 PM
