NEED HELP WITH H.I.D wiring
Old Apr 30, 2007 | 04:56 PM
DaREDss's Avatar
How do I wire it to the battery if its in the trunk????? Do have to buy longer wires or is there somthing under the hood i can connect it to??? thanks guys
Old Apr 30, 2007 | 05:01 PM
neodude101's Avatar
http://www.youtube.com/watch?v=LbJxdhaWJnk
try taking a look at this video. The very first thing he shows is where to tap the power from.
Old Apr 30, 2007 | 05:05 PM
tiny's Avatar
if it is plug and play, it should connect to your stock harness, it uses an ignitor and ballast for power under the hood
mkulrey13's Avatar
wire it to the + post in the fuse box.... do people not know what that is?
Old Apr 30, 2007 | 05:10 PM
SilverSS/SC's Avatar
For my HID harness I used the available terminals in the fuse box . Theres like 4 slots that have constant 12v battery power . Just use a flat male blade connector . Nice and clean that way . Theres even a slot in back left of the fuse box to pass the wire(s) thru .
Old Apr 30, 2007 | 06:33 PM
DaREDss's Avatar
thnx guys I can always count on you
what do i do witht the 2 lil prong things???? it says slide into the female slot or splice them splice them to what????
pleez this and im done!!!
Old Apr 30, 2007 | 07:02 PM
Just take the male blade terminals , crimp them onto your wires , and slide them onto the female blade terminals in the fuse box . Theres 4 blade terminals open in the back of the fuse box next to few of the fuse links . All 4 of them have constant 12 volt battery power .
Old Apr 30, 2007 | 07:39 PM
oldsskool's Avatar
The 2 that you are talking about are the ones that gave me grief, till I thought about it. Those 2 need to be spliced into your headlight wiring harnass on one side only (if you are using the supplied relay).
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
