high beam/low beam
Old Jan 28, 2012 | 07:34 PM
deereboy4320's Avatar
high beam/low beam
is their a way to make it so that when you turn your high beams on, your low beams stay on as well?
Old Jan 28, 2012 | 07:36 PM
Sweetsandman's Avatar
Are you on OEM Headlights? If so...then No.
If you're on Gen 1-4 headlights:
https://www.cobaltss.net/forums/how-...jectors-68252/
Old Jan 28, 2012 | 09:12 PM
Yes I am on OEM. I am surprised there is nothing out there to make this happen, it would be so nice
Old Jan 29, 2012 | 02:28 AM
08SStc's Avatar
Id imagine with a proper relay set up that it would be possible. I had that done to my blazer when i still had it
Old Jan 29, 2012 | 02:52 AM
Maven's Avatar
Its possible but barely worth the effort, as light output isnt that much better,turning your lowbeams on then pull back on the flash to pass feature, this is hi/lo at the same time.
Old Jan 29, 2012 | 07:22 PM
yes I know pulling back on it makes them come on together but my light output is much greater when both are on. wanted to make it so they came on together. how would one go about making the relay?
Old Jan 29, 2012 | 07:24 PM
TommyP's Avatar
AWD > FWD
The light may be brighter, but it's less USEFUL. When trying to see in the distance you don't want light up close.
Old Jan 29, 2012 | 07:34 PM
Maven's Avatar
you dont need a relay. you just need a 10amp diode.
Old Jan 30, 2012 | 12:09 PM
how would this work?
Old Jan 30, 2012 | 06:17 PM
Maven's Avatar
It would work how diodes work
Old Jan 30, 2012 | 06:22 PM
N1ckateen's Avatar
HID's
Old Jan 30, 2012 | 10:27 PM
I've never played or even looked closely to a diode.
Old Feb 1, 2012 | 04:08 PM
ScottxKillyou's Avatar
a diode works like a one way street for electricity. if you hook it up directly between your high and low wires with current flowing towards the low then when you turn on the high beams current will flow to the low as well, but when your lows are on nothing can flow to the high.
Old Feb 1, 2012 | 05:01 PM
ahhhhh I see. how big would this diode need to be?
Old Feb 1, 2012 | 11:21 PM
Maven's Avatar
ten amps.......
Old Feb 2, 2012 | 12:40 AM
kasper_17's Avatar
no_ss
Oct 18, 2015 11:58 PM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Slick_Nick
Sep 28, 2015 09:15 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
