high beam/low beam
Are you on OEM Headlights? If so...then No.
If you're on Gen 1-4 headlights:
https://www.cobaltss.net/forums/how-...jectors-68252/
Its possible but barely worth the effort, as light output isnt that much better,turning your lowbeams on then pull back on the flash to pass feature, this is hi/lo at the same time.
yes I know pulling back on it makes them come on together but my light output is much greater when both are on. wanted to make it so they came on together. how would one go about making the relay?
a diode works like a one way street for electricity. if you hook it up directly between your high and low wires with current flowing towards the low then when you turn on the high beams current will flow to the low as well, but when your lows are on nothing can flow to the high.
DANRICKARD
Oct 1, 2015 12:08 AM
