holes after removing spoiler
hello everyone uhh i remove my spoiler and was wondering is there only one way to fix the hole problem..uhh does like a body shop just weld the holes shut? they have to repaint sand all that stuff? just wondering and trying to think about how much work and money it will cost me just to get 4 holes filled. anyone know what it costs??
that is true. i didnt think about getting rid of the key hole that would look a lot better and clean..well ima go to see how much it will cost. ill post it up just incase anyone is interested. thanks guys
The only right way to do it is to have the holse welded and trunk lid painted. Depending on the color, they may even have to blend your quarter panels to get a color match. I would have them shave the trunk lock cylinder too if you are going that far. Cost really depends on the shops labor rates, quality of materials and techs they employ and how much they want to do the job. I will be honest, but there are some jobs we get that I just don't want to do so I will give an obscene price quote so I know they won't bring it to me. If they say yes to the obscene price, well then I couldn't afford not to do it. If quarter panels don't have to be blended, I would say a good shop willl charge between $400-$600.
depends if you do the work your self befor you take it to the body shop, not to hard to fill in the holes and prep it befor hand, saves you a few hours in labor at the shop which = money in your pocket
I only suggest doing that if you have experience in doing body work. If you have no experience then do not attempt to do it. It is not as easy as some people may think and it could cost you more to to have the shop undo what you did and then fix the original problem. I get a lot of "do it yourselfers" at my shop and out of the many that have showed up with their own body work, only one did it right. The rest just took blind guesses at what to do and it cost them.
i was quoted 582 by a chevy dealership to fill in and repaint the four holes from the spoiler, as well as the keyhole removed. keep in mind its a quote by a dealership, so expect that to be on the high side.
One thing when removing your lock cylinder from your trunk is some of you guys have your battery in your trunk. If you disconnect your battery for some reason then close your trunk with no lock cylinder, you will have a hell of a time getting your trunk back open and the battery re-connected. Just a thought....
i fucked my trunk up a bit. the holes are raised a little so i think silicon will not do justice. either put diff spoiler on or go to body shop i think. did it in dark lol didnt notice that the holes are lifted a bit from the bolts coming out sideways from lifting too high on one side :-/ go me
if it came down to it. would climb in the back seat to the trunk to reconnect the battery lmao. and is all the ss/sc batterys in trunk cause for a while i didnt know where mine was lmfaoa hahahha
Last edited by 05bLkCoBaLtSs; Nov 23, 2007 at 08:40 PM. Reason: Automerged Doublepost
i got rid of the trunk lock on my cavalier, but i had a manual release inside of the car, if the battery was to die you would have no way into the trunk
does anyone know how much the ss spoiler weighs? the high rise? trying to ship it and trying to estimate the shipping cost based on weight to let the person know and for my own knowledge. thanx if anyone knows it would help me out a lot..im guessing 7-10 lbs
Good guess mine just weighed out 9 pounds.
You just want to learn the hard way don't you. Do you even know how to use bondo or what it's intended purpose is? I don' think you do. Please save yourself some trouble and pay the money for a quality job or go the carbon fiber route like someone else suggested.
you'd have to be super thin to get through the seats. the release switch to drop the seat backs is at the trunk opening, not at the rear seats. i wouldn't even want to think about how to open the trunk in that kind of situation. definatly something i never thought of!
soccerkid13
Jan 11, 2016 10:25 AM
Cptnslo
Sep 24, 2015 09:32 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
