hood dont shut right someone help me
hey whats up i bought a carbon fiber hood from CA and it doestn close up tight. when i shut the hood the right side fite real tight (actually to tight)and the drivers side has like a quarter to a have inch gap. is there any trick s to getting the hood to align up right ????
Oh if that's what he's talking about, I had that as well....What fixed my problem is I put two washers in between the hood bracket and the fender on the side that the hood was really close to. It did the job....Also when tightening the hood to the brackets make sure the hood is aligned straight before tightening them or else it will be crooked
There is some play in the hood. loosed up the bots that hold the hood to the hinge and move it around. Also you could see if there is any adjustment on the hood latch itself. Im what not sure how easy that is to get to but that will also affect the hood fit. Aligning panels is a bitch
yuo have to change the hood strut. i had the same problem with mine. i sold the hood to jackalope here on the forum nd he got a different hood strut and it was perfect after that. the stovk hood strut is made to hold up a steel hood. now with the cf its pushing to hard and causing it to stick up 1/4". its an easy fix.
I had to adjust mine down cuz the hood shut so tight its started to crack a little where the rubber pieces were
roth
Sep 26, 2015 12:16 PM
