Inner tail light mod? Corvette style.
Is there any way to illuminate the inner tail lights on the cobalt coupe?i think i saw a thread on this, but i haven't seen any one with them working. Is there a kit out?
https://www.cobaltss.net/forums/pictures-videos-64/morning-sunrise-82828/
i got aftermarket tail lights the leds and the way you wire them up causes all 4 to light up its just the way they wire it if you guys need a way to figure it out i could tell you hoe to wire it its easy
Yeah, I would say to make them all light up, just tap the power wire from the original brake light.
I'm getting a spare set. The outers are staying LED. The inner (outer Circle) will be red and illuminate in a ring like the outer. The Inner where the white reverse light will be red and the new turn signal bulb.
Then after everyone brought it up the G5 looks like a nice idea.
I am going to wire the turn signal to both the exterior lamp where it is, then where the white reverse lights use to be. So you will see two Circles flash red when the turn signals are on.
I'm just having trouble thinking of the best way to make the white part of the lense red. I could use acyrlic plastic and melt a new lense with added red dye, but then I would have to do both the interior and exterior lenses. I could use fiberglass to make a mold then use ABS Plastic and red dye to do the same, but the same problem. Red transparent paint is gong to look cheap. We have a hot knife that would cut out the white part, but to make it red again by attaching another red lense cover would probably be hard to make look good and not tacky.
Anybody know of any lenses that are completely red that are about the same size or style as the interior lights? I know the Passats, but I am talking about the exterior lense, not the actual circut board part.
i did a skyline taillight conversion check out the vid on this.
https://www.cobaltss.net/forums/appearance-48/my-buddies-turn-signals-rearof-his-cobbalt-%2Avideo%2A-77378/
or maybe the tansparent red and a light nightshades black... but i see the problem with trying to make it blend together... how about buying a spare outer tail light and using that as a cover
