Installed HID's
Old Feb 9, 2009 | 12:56 PM
chevyguylt1's Avatar
Installed HID's
I installed HIDs Saturday afternoon. The installation went alright. Had a few minor hickups, nothing to big. The install was sucessful !
I am just wondering if anyone has removed or cut off the plastic sheild inside the headlight? The HIDs are bright, they just dont go FAR? Seems my stock lights went out further from the car??!!
Anyone ever remove the sheild or trim it?
Thanks for any help!
Hunter
Old Feb 9, 2009 | 01:09 PM
tdipowered's Avatar
HIDs in reflectors arent good for business...you want a difference then pick up some projectors man
Old Feb 9, 2009 | 06:19 PM
yobrigidey's Avatar
Hunter
Hmm, judging by the complaint, I'd say you went with 8,000...10,000, (gasp) 12,000k HIDs?
People get too caught up in the numbers and marketing propoganda with HIDs.
Your stock 50 w. Halogen lamp outputs 750-950 lumens
8,000k...2500 lumens
10,000k...2200 lumens
12,000k...2100 lumens
BUT
Your eye is MUCH more sensitive to white and yellow light, and has a VERY tough time proecessing blues/purples. Therefor...even though you are technically getting higher numbers with a light meter, your eye cannot pick up details with blues/purples.
My apologies if you did purchase a 4300k kit or even 6000k. Still, put 'em in projectors and you'll see a HUGE improvement.
Old Feb 9, 2009 | 06:25 PM
MikeyMo84's Avatar
yeah def dont cut off those shields that will make the glare horrendous and prob make the light output worse...
Old Feb 9, 2009 | 06:57 PM
MaxVQ35DE's Avatar
the reason that the light doesnt go that far is because the stock reflectors are pretty horrible.
Retrofit>Ebay housings>stock housings
Old Feb 9, 2009 | 06:59 PM
REIGN SS's Avatar
Original Hayden Fanatic
*Moved to Appearance*
Old Feb 10, 2009 | 11:23 AM
TheCaptain's Avatar
That's for sure!
Old Feb 10, 2009 | 11:54 AM
DaBuzzard's Avatar
1 - Aim your headlights. The bulbs may be sitting in a slightly different position than the halogens were. Just don't go too high, these are low beams after all.
2 - DO NOT REMOVE THE SHIELD!!!! This is what provides the cutoff on these type of headlights. Without it you will have full time high beams....not good to say the least.
As pointed out by others above, invest in a set of projectors if you want to run HID's. The light output and beam pattern will blow you away
Old Feb 10, 2009 | 12:00 PM
chris88z24's Avatar
Aim them up a little... I have mine aimed kind of high, if I am coming up a steep hill I get the occasional ******* that will flash me.. I just flash them back and honk at them lol. Tough ****, trucks are much brighter than a little car with hid's in the headlights. I get blinded numerous times at night from peoples bright ass lights, so I am not aiming mine down further anytime soon. **** it, lol.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
