installing AVS tail lights covers
I just received mine and i was wondering if the double sided stickers are really doing the job or if i'll need something else to do a proper install ??
Thanks
Thanks
I installed mine with just the double-sided tape. They seem to stick really good. The only thing I regret, is not doing a couple test placements before I took the plastic backing off the adhesive...other than that you will be quite pleased with them i assure you.
I installed mine winter timeish and so far no problems, everytime i walk behind the car i give em a good push to make sure they arent coming loose and so far no problems, and i live in ohio too, i just wish it would make up its god damn mind haha
Apologize to bring an old thread back.
I just installed these AVS covers the other night; and it looks horrid when you turn the lights on. The double sided tape shows right through; and the fitment is a bit tacky...
During the day they looks great though...
Any suggestions guys?
A soon as I got them I put new tape on them and actually made the tape look like a circle instead of the ghetto zig-zag they had going on and you can't even tell they weren't supposed to be like that.
Ok guys.... here is the secret. Remove the double sided tape and use a silicon sealant like you do with headlights. I used liquid nails. It is completely clear and will still give you the smoked look (as opposed to black) and does not obstruct light output. Not to mention, there is NO WAY that stuff is coming off regardless of weather
it was some marine water proof stuff in a blue tube that i got from a local auto zone just make sure you ask if the stuff will be able to come off but i think if the stuff from the headlights can come off with a hair dryer most every thing can come off with a hair dryer it was also for plastics
