Installing Cathodes
Old Dec 4, 2007 | 05:48 PM
ChiGoku's Avatar
Installing Cathodes
Hey guys, I have been searching the forums under the how-to's, and even search function.
what I am looking for is a good detailed instructions on wiring cathodes lights I bought for inside my car. I already have them under my dash strung up with zip tie's and double sided tape, from what I was told, I could just slice the wires into the cigarette wiring by my E-brake as it provides the right voltage I need. and ground it out by my e-brake (with the cover off)
I bought a switch for my lights which have three wires, so I am guessing 1 is for on, ground and off.
I took off the cover by my e-brake and saw the wiring for the cigarette lighter, but kinda confused on which wires I would actually need to splice into. I got the lights from http://www.oznium.com/ so I have the Dual Cathode Transformer and the switch from them.
But the transformer has two wires, and the switch itself has 3, where do the two wires of the transformer go to, does it go to the switch?!? then only 1 wire from the switch goes to the spliced wire of the cigarette?
any detailed help, pics, a diagram, or even point to the right direction would be a lot of help!, Thank you
Old Dec 4, 2007 | 05:52 PM
Whitnith's Avatar
Ok. So, I have two of those kits of Oznium installed in my car right now.
You need to run one wire from the transformer to the switch, and then another wire from the switch to the power source, making a loop. The third wire on the switch is to ground, and the transformer needs to be grounded as well.
I hooked up everything to a little plug that just goes right into my cigarette lighter like a cell phone charger. Provides a ground source there as well, as you don't have to splice into wires.
I'll make up a little diagram and post it here once I get it done.
Old Dec 4, 2007 | 05:56 PM
ChiGoku's Avatar
okay that would be awsome, even it is a pencil/pen drawing ^_^ and you take a pic of that and posted it
so it makes sense, 1 wire from the transformer to ground, and 1 to the switch, and then so 1 wire from the switch to a ground, and the 3rd one of the switch to power
kinda makes perfect sense, thank you for the help so far, I just didn't think I had to ground the transformer, so I was kinda stuck on that part and was wondering what to do with an extra wire :P
Old Dec 4, 2007 | 06:06 PM
Whitnith's Avatar
Mmk. Here ya go. I think that makes sense..
Old Dec 4, 2007 | 06:08 PM
Cobalt30's Avatar
I noticed that somebody above posted a long thing saying how he hooked his up. but I will explain as well lol
the switch has 3 prongs. 1 source, 1 power load, 1 ground.
the catholds have a "transformer box" out of this box after the 2 lights are plugged in the other side has a positve (red) and negative (black)
ground the black wire on the catholds.
attach the red wire from the catholds to the source on the switch.
attach the power load (12v cig. lighter) the red wire to the load wire on the switch
ground the switch with a black wire to the frame or something
I did try posting a how to on all of this like last friday but they never accepted it apparently
Old Dec 5, 2007 | 12:49 PM
TheDaves413's Avatar
Yeah Cobalt30 hooked mine up for me, he knows what he is talking about with them.
They look awesome, not even a tad bit rice!
Old Dec 5, 2007 | 12:59 PM
Cobalt_SSTuner's Avatar
very nice!
made perfect sense to me....even though i have them already installed on my car too.....
time for piktars
yes, i know my floor is dirty, and they are a little brighter in person, i took the pictures with my phone
oops ignore the last one....not inside the car
Last edited by Cobalt_SSTuner; Dec 5, 2007 at 01:00 PM. Reason: Automerged Doublepost
Old Dec 19, 2007 | 08:11 PM
ChiGoku's Avatar
Thank You everyone for the How-to, It made perfect sense.
But I'm afraid the lights don't work The switch lights up, so I have power. the transformer that the lights are plugged in, lights up. So it has power... just the lights itself don't come on. I even kept it on for a few mins maybe thinking it takes time to warm up... nothing
So, I thought it may be because I had to much on drawing power... So I unplugged 1 light (as there are two) nothing. I by-passed the switch. plugged the transformer directly to the power source and it lights up again so its getting power. but the lights still don't light up.
I checked and double checked the wires, checked the grounds that they were proper. removing the ground made the lights go out, so I know I have good ground.
Any thing else I may have missed, or suggestion?? Or do you think I just got bad lights??
P.S. I used the Cigarette lighter 12V. So I cut the red wire of that. now the black wire is still in tacked to the Cigarette lighter, do I cut that up and re-ground it also???
Old Dec 19, 2007 | 08:14 PM
jefferyss's Avatar
why dont you just ask me to help you?
Old Dec 19, 2007 | 08:43 PM
ChiGoku's Avatar
I had a few times actually ^_^ but no response, I asked a few times in the forums and I guess you were kinda busy and skipped over it, its no biggie, but do you think what else may be the issue Jeff??
never mind.. found out what the issue was.. seems like the tubes itself are cracked.
Don't know when it happened. As the lights were placed under the dash and glove box. 3-4 months ago. so they were on there for awhile, just never hooked up for lighting till now. And the tube is cracked in the same spot for both of them..Not sure if it was something I didn't notice untill after shipping or not. so Time to place an order for more now O.o
Old Dec 19, 2007 | 08:49 PM
Whitnith's Avatar
yah, getting the lights in one piece is a challenge. I have 4 lights, have gone though probably 10 lights... They come broken, get kicked by accident... etc. At least they are cheep.
Old Dec 19, 2007 | 09:25 PM
ChiGoku's Avatar
yeah. placed another order as soon as I found out what was wrong, 6.95 for lights, and like $6 bucks for shipping.. oh well, its pocket change pretty much, just glad they are so cheap :P
Old Dec 20, 2007 | 01:29 AM
jefferyss's Avatar
sorry man,last time i remember you asking me was at a&w that night and you had asked me if i had a pair of pliers to connect the wirring on me lol. i don't read everypost in the forums or therefore spend all my time in here,i come in and read and post when i have time.it's nothing personal at all.remember, i work a day job and a night job so i'm all over the place .
pm me when you get more lights in and this way i know that your ready and we'll set something up to install them for you.i'll come to your garage and install them for you.just let me know k
Old Dec 20, 2007 | 04:56 PM
ChiGoku's Avatar
Hehe, no problemo Jeff, I understand your busy with what you do, so it was no big deal. So everything is all hooked up, and when I get my lights, there is actually nothing to be wired now. since it is all done, the Transformer is still hooked up to the switch etc. So when I get the new lights, I just have to plug them into the transformer and thats it ^_^
But one thing for sure, is when I get a new box for my subwoofer, I am definitely going to need your help on wiring that up
Old Dec 20, 2007 | 07:15 PM
jefferyss's Avatar
FOR SURE , LET ME KNOW AND GIVE ME SOME WARNING LOL
Old Dec 22, 2007 | 12:27 AM
avenger09123's Avatar
Hey man, I saw you had problems with your underdash setup. Here's what I did: I got 2 of them, they are 2 different kinds, both have sound sensor switches, but one had a built in transformer and the other had a separate transformer.
All I did was cut off the 12v plug end so I had the 2 wires, they were plenty long, so I had my switch on the floor, my 2 lights on either side on the floor. I ran 1 power wire from my + on my batter to the switch. used an electrical fitting and hooked up both + from the lights into one fitting, and then both - and the batt - into one fitting. Slid those onto the switch and tested the entire system before I installed it, it took a little while, and I had to turn off the sound sensors, sometimes 2 or 3 minutes, but the transformer's spool up and then the lights flick on, eventually. Remember neons are like 30,000volts and small small amps. Then I stuck the lights under the dash with tape, and then I screwed the switch under the dash on the driver side, right next to the console. If you have a dremel you can cut out and pop the switch in itself instead of using the screw attachment it has......i can give you pics if you want.....
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
