Installing my HIDs....NEED HELP!!!
Old Sep 11, 2008 | 10:39 PM
BlackSSNick's Avatar
I bought an HID kit from 3B specialties. It's an H1 mix and match kit with a 9007 harness. I don;t understand it thought because it has a relay and each bulb has a connection that plugs into the ballast, but the harness also has a connection that plugs into the ballast and theres only one spot on the ballast to plug into. Also the part on the hid kit harness that plugs into the stock harness attached to the headlight assembly has two wires...white and black hanging off of it that arn't connected to anything....
Can anyone help me out?
Last edited by BlackSSNick; Sep 11, 2008 at 10:39 PM. Reason: Automerged Doublepost
Old Sep 11, 2008 | 10:46 PM
jefferyss's Avatar
is it a high and low beam set-up or just a low beam? if its a high and low beam set up the black and white wires should be for your high beams i would assume.if that is the case white wires should go to i beleave the pink wire on the harness and the black would go to a ground for the high beamms to work. now keep in mind this is without seeing the kit hat you have.good luck and post some pics of the set up and maybe i can help you more.
Old Sep 11, 2008 | 10:55 PM
i'll get you some pics 2marrow, but it's one 9007 harness with a relay
Old Sep 12, 2008 | 12:05 AM
wardzach2007's Avatar
This man, speaks the truth.
Old Sep 12, 2008 | 12:08 AM
jefferyss's Avatar
thanks bro !
Old Sep 12, 2008 | 12:09 AM
Even though, pics would help alot. Your "paragraph" made my head hurt. Visual aids help me out better.
Old Sep 12, 2008 | 12:32 AM
jefferyss's Avatar
https://www.cobaltss.net/forums/how-guide-43/how-hid-installation-92078/
- you could problably pm him for bigger pictures, i went through all 12 pages of how to's to see if anyone posted a how to on h.i.d.s. and this is the only one i could find...good luck man
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
