LED map lights
Step 1
GET THIS DONE NOW!!!
step 2
send me blue bulbs for my map lights.
Step 3
send me a paypal bill to my emaill address
Step 4
I post great pics with yet another one of your mods
Step 5
add another item to your online store, make $$$$
end hijacking thread now
njg5gt did it on his car with red lights don't know if he posts here but he's on g5club
http://www.g5club.net/forum/garage.p..._vehicle&CID=6
awesome man. I hope you figure something out. I took the mirror down and didn't see any part that would allow me to take the mirror apart.
Last edited by th0ughtless; Nov 19, 2007 at 12:12 AM. Reason: Automerged Doublepost
JamesJJP put a red film over his.
I replaced my Map Lights with Ultra White LED's. You do not need to disassemble the mirror but let me tell you getting the bulbs out are a bitch. I used a slip knot in some fishing line and fed it around the bulb and pulled it tight around the base so i could just pull them up and out. Its a very pain in the ass process but I could find no other way.
BTW the ultra white LED's look amazing in the car.
I have done 2 different LED's. But first I must say this: If you need to be able to see what you're doing in your interior DON'T BUY THESE. lol. Don't get me wrong, they look amazing. However they're just not very mega bright. Plus, I have a sunroof, so seeing what's in my back seat is impossible even with normal lights, but even with the LED's it's no different. First off, GM's mirror design is ******* retarded. Honestly. It took me about 30 minutes to do the Cobalt each time, and I still haven't been able to remove my dad's mirror bulbs from his '04 Monte SS. But using good tweezers is the trick. I first did blue (because dumb me didn't look at the packaging properly). It was super duper dark, but you could actually drive around with them on and it'd make an awesome accent effect. But I now have whites. It looks about 500% more awesome than normal factory lighting, but you can't see dick. If form overides function here, you're good to go. However if inside lights are integral, I'd either leave factory lighting, find some incredible bright LED's that will cost like 5x more, or just carry around a flashlight to use since the LED's look bangin'!
I have done both my map lights and my plate light. . . pretty easy if u know how to do it....careful with the plate light tho...ive gotten pulled over MANY times for it......if you would like me to do a HOW TO...just let me know
lexus's come standard with em...tell the cop to **** himself
mine was LED till it got all fucked up so now im back to normal till i get a replacement (ie. stealing the one i gave my bro off his car tomm ;-))
Thats basically what mine look like except brighter.
My LED's actually use so little power that they have a constant glow from the small amount of power running through the lines even when off.
From the front at night you can see that my map lights are still on slightly. lol
LOL I have been pulled over once for my plate light. It was a city cop who told me that I should replace it back to stock cause "the state boys" would like it. There is nothing that they can do about it.
I did this as well . I used a 194 bulb that had 4 narrow angle white LED's in a star pattern to reflect of the housing and 1 high power wide angle LED in the center . Bought the LED'd at superbrightleds.com . Light output is amazing , much greater than the stick incandesents .
If u install a diode in between the - and positive map light wires they will turn completely off when not on .
Last edited by SilverSS/SC; Nov 21, 2007 at 05:57 AM. Reason: Automerged Doublepost
I'd be interested in attempting this.
