LED map lights
Old Nov 21, 2007 | 10:24 AM
Jondevos's Avatar
I have the same issue with not being able to see in the back of my G5 so I put leds under the seat. They are only hooked into the door switch right now but I am going to be adding in toggle switches (already have) to allow me to turn them on at any time.
Old Nov 21, 2007 | 10:32 AM
OrngBalt's Avatar
Originally Posted by SilverSS/SC
If u install a diode in between the - and positive map light wires they will turn completely off when not on .
Thanks for the tip... they aren't bright and I kinda like it. but for a good idea
Thats ******* cool dude. I wanna put neons/LED's in my interior as well and I was gonna toggle switch them, but I kinda like the idea of them turning on automatically when the door is open. How did you do that? I am sure you just tapped the switch for the door but pics would be kool. I wouldnt mind having the lights turn on with toggle switch and when the doors open.
Old Nov 21, 2007 | 10:34 AM
bruff1977's Avatar
Hey LED folks, did you lose your theatre-style lighting? Sounds like a good idea to switch them out, but I don't want to lose the theatre-style.
Old Nov 21, 2007 | 10:38 AM
njg5gt's Avatar
i believe its done with a relay, and the togle switch just bypasses the relay
averagewhiteboy's Avatar
Mine did at least. When you close the door, it stay on for a couple seconds then cuts. You can't really do that with LED's. They're basically on or off, correct?
Old Nov 21, 2007 | 10:41 AM
OrngBalt's Avatar
Nope, I didnt lose mine. Since all it is doing is reducing the power to the lights gradually, they still dim, just like any other light being starved for power.
stealthy1ss's Avatar
Mine still dim slowly but it isn't as smooth as the original lights.
Old Nov 21, 2007 | 10:46 AM
redlineblueline's Avatar
red saves your night vision but still has the same output so red would be an ok color
Old Nov 21, 2007 | 11:08 AM
I had a little blue neon actually under my back seat, so like you couldn't see the tube, but it illumnated the rear floor. It was dope. But then it burned up. lol.
Old Nov 21, 2007 | 11:40 AM
refuge4's Avatar
Is this the two wires in the wire harness that go into the mirror/dome that supply the door open lighting or is this somewhere else?
Old Nov 22, 2007 | 11:16 PM
  #36
OrngBalt's Avatar
Jondevos.... how did you hook that up with your lights?
Old Nov 22, 2007 | 11:24 PM
  #37
Jondevos's Avatar
I wired them through the door switch. Tomorrow Ill try to do a little writeup.
Old Nov 22, 2007 | 11:37 PM
  #38
OrngBalt's Avatar
nice, does it work with both doors or just the driver?
Old Nov 23, 2007 | 08:51 AM
  #39
EmperorJJ1's Avatar
I did this as well . I used a 194 bulb that had 4 narrow angle white LED's in a star pattern to reflect of the housing and 1 high power wide angle LED in the center . Bought the LED'd at superbrightleds.com . Light output is amazing , much greater than the stick incandesents .
is there a certain type of diode that needs to be used?
Old Nov 23, 2007 | 08:58 AM
  #40
Jondevos's Avatar
OK, so Im not completely finished yet with my led project. I only have the driver side wired up so far. Im going to be doing the passenger side soon too. This is how its going to work. The lights under the dash and under driver seat are hooked to driver door and the lights under dash and under passenger seat will be hooked to passenger door. I am going to have 3 switches in the car to go along with them as well. 2 switches will be so I can turn on the left or right side while the doors are closed (lets say you drop something on the floor). The third switch will be a connecting ground that allow all the lights to come on when either door is opened instead of just the lights on that side of the car.
Wiring them is very easy. I wired the positive into a add-a-fuse. I put the fuse in slot 27 I think. Any slot that is constantly live even with key out will work. I wired the ground into the gray wire that goes to the door switch. When the door is opened the lights are grounded allowing them to come on. All the wires I ran behind the trim pieces on the centre console and under the dash. Only took about 30 min to do and looks awesome.
On a side note I plan on wiring single blue LEDs into the bottom of the door panel to light up the ground below the door when it is open. This will add a lot more visibility while getting in and out of the car.
Old Nov 23, 2007 | 03:35 PM
  #41
ViSiONZ's Avatar
Sounds good, make sure you take some pictures & possibly do a how-to
Old Feb 23, 2008 | 02:14 PM
  #42
Grave's Avatar
So it turns out that on 2008's they changed the map lights to led. I assume Cobalts are the same, not sure though. Anybody looked yet?
From my limited knowledge of led's, it appears to be a surface mount style. (sorry, can't really see it good in the pic)
When lit it's yellow to fool you into thinking it's a regular bulb that you can change with a blue one that you already bought lol
I don't see anyway to change this light unless you take the mirror apart and desolder it. Any other ideas????
Old Feb 23, 2008 | 02:32 PM
  #43
SilverSS/SC's Avatar
That would be the only way to do it . Those OEM circuit boards are so closely spaced and the solder points are so small on the surface mounts you'd about need a solder sucker to recover the solder off the board , then re-solder with new . The entire mirror is likely plastick welded together though , so it may be a can of worms trying .
FYI , the cadillac version of the same mirror uses bright white LED's .
Old Feb 23, 2008 | 05:08 PM
  #44
Grave's Avatar
I probably won't mess with it. When I had the mirror out, it felt like the actual mirror part might pop off, but I didn't want to break it.
Old Feb 23, 2008 | 05:20 PM
  #45
biniecki's Avatar
here is a how to from the g5 site but it doesnt use the stock mirror
http://www.g5club.net/forum/viewtopic.php?f=27&t=1723
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 04:49 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
