LED Replacement lights?
Originally Posted by Brian MP5T
I have some kicking around if you can't find them..
PS. Sshaner... I have Silverstar headlights.
Before getting load resistors
Check to see if our car's have an electronic flasher or a mechanical flasher. I'd start by getting a heavy duty electronic flasher. My brother hasn't had any trouble with LED's in either of his trucks. The turn signals and the hazards use two different flashers (or they have in the past).
Good pics, looks like good lens fill to me. Are you more satisfied now?? I'll be ordering mine pretty soon.
Scott
Scott
Scott
Scott
Honestly, I would hope it is under the hood but, I doubt it'll be that easy. The interior fuse panel is a little bit touch to access. I thought I was gonna break my cover just trying to get in there to look at it. I'll take a look tomorrow and see if I can locate it. Here's a hint: switch the car on, switch the turn signal on and listen closely; if you can't hear it without taking the covers off, then once the covers are off you should be able to feel it "clicking."
Happy to hear that you got more of what you were looking for with these bulbs. I went on the site the other day and made out my complete list of bulbs (9 total). I still have to see about pulling a fuse to kill the DRL's so that they won't fry my LED bulbs. Superbrights says that there is a pulsing current to some DRL's that causes all of the bulbs to fail in that application.
Scott
Scott
Scott
Scott
When installed on the supply wire, they will fix all that.
So there is no need to rip appart the car and start ordering odd relays for the blinkers.
DANRICKARD
Oct 1, 2015 12:08 AM
z28addiction
Sep 28, 2015 12:03 AM
