led tail light bulb issue
so i had gotten led bulbs for my tail lights like a month or so ago. everything worked fine when i first put them. installed the load resistors and no hyper flash. the other day some one layed on the horn at me when i was making a turn. i was like dude wtf is your problem. it was buggin me so i had my brother take a look at when i use my turn signal. they work just fine until.... i hit the brakes. lets say i go to turn right. right one blinks, but when it goes back to normal, the left one changes as well. thus they alternate when i use my turn signal with my brake. wtf is going on?
neither bulb has any leds that look out?
try this on one side swap the bulb around 180 degree then put it back in. See what happens. if no change revert back to the way it was originally and try the other side. if still no change then idk gl
I ran these found them on eBay for $18 a set,and I had the same problem. I had to rotate them 180° cause they were bright when they were on for running and then dimmed for blinker and brake. That fixed them.
