Lets see your engine bay!
Old Feb 19, 2011 | 01:10 PM
  #1576
1LowLS's Avatar
Thanks.its messy.ill clean it up later haha
Old Feb 19, 2011 | 07:47 PM
  #1577
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by StevesBlack06
needs black AN fittings!
black sucks! needs color imo. wait until the other things are powdercoated.
Old Apr 13, 2011 | 11:58 PM
  #1578
The Azian's Avatar
Soo I'm not very familiar with taking off engine pieces, however I wana paint my engine cover and I was curious to know if anyone can tell me what precedure needs to be done in order to remove the engine cover. Sparkplugs have to be removed? Someone let me no!
Old Apr 24, 2011 | 03:21 AM
  #1579
10Cobalt_SS's Avatar
How did you guys go about painting the valve cover i went to paint mine and it fish eyed and started to orange peel
Old Apr 24, 2011 | 03:22 AM
  #1580
heathkidder's Avatar
how did u prep it?
Old Apr 24, 2011 | 10:08 AM
  #1581
startingline05's Avatar
sounds like you didnt prep it good
Old Apr 24, 2011 | 10:14 AM
  #1582
StevesBlack06's Avatar
if it fisheyed then its prob oily. i took mine off, sprayed it with engine brite let it sit for a while then spraped it w some brake clean. i hit it w a scotch brite pad and then brake clean again. after i had it how i liked it w the scotchbrite pad i cleaned it w soap and water, had to use a toothbrush to get down into the corners and tight spots. then i gave it to my buddy and i think he even cleaned it again b4 he shot it.
Old Apr 24, 2011 | 10:21 AM
  #1583
tityrous's Avatar
Old May 4, 2011 | 07:04 PM
  #1584
gone_in_10_sec's Avatar
Unhappy Grape Ape!!
Still alot more to do.. especially the Intake Mani/ Fuse box/ ECM/ Coolant tank/ Oil Catch can.. Custom ordered Samco Sport hoses and lines, just waiting for them to clear customs at JFK..
Old May 4, 2011 | 07:12 PM
  #1585
matt638's Avatar
^thats sick!!!!
Old May 4, 2011 | 08:00 PM
  #1586
Originally Posted by matt638
^thats sick!!!!
Thanks, just the wiring loom itself took me 4 hours, a 1/2 hr to pull it all out and 3.5 hours to replace all of the stock black convoluted tubing and zip ties, and then replace all of the stuff with purple [loom/ zip ties/ electrical tape] and then put it all back in place..
If anyone want me to replace or update there wiring loom, send me a PM..
Mr. Gasket # 11031P G-Sport Pro Vacuum Hose Kit - Lite Purple
Taylor # 38001 - Convoluted tubing assortment Kit - Purple
Taylor # 43012 - Cable Wire Ties; 8 in. Length; 25 Per Package - Purple
Hose Candy - Master Kit - Purple
I still have more to get ur done..
Old May 4, 2011 | 08:19 PM
  #1587
C_A_D88's Avatar
imo thats to much purple, n pink, i woulda left the looms bl;ack
Old May 4, 2011 | 09:04 PM
  #1588
the vacuum lines are lite purple, [the picture makes it look pink] but once all of the Samco sport stuff comes in, it will match everything nicely.. i'm going for show, the black wiring looms don't win awards, color does..
Old May 5, 2011 | 03:01 PM
  #1589
cobalt523's Avatar
Originally Posted by biniecki
Here is a pic of mine. Its an older pic but not much has changed.
where did you get that carbonfiber cover?
Old May 6, 2011 | 11:39 AM
  #1590
ChevyRockstar's Avatar
Need to repaint some stuff and get new pics on here
Old May 6, 2011 | 01:36 PM
  #1591
C_A_D88's Avatar
just they stand out way to much the black blands in and makes for a cleaner looking bay imo, all the bright wiring looms just makes it look messy, just my opinion thiough
Old May 7, 2011 | 12:02 AM
  #1592
i hear ya.. but after going to a few shows, most of the rides that have won, either have colored looms or hidden wiring..
plus i got tired of black looms, it just looks like every other cobalt out there with the stock black looms.. just trying to standout from the sea of cobalts at shows/meets..
Old May 7, 2011 | 12:44 AM
  #1593
FatSam2010's Avatar
still alot more to do.. Especially the intake mani/ fuse box/ ecm/ coolant tank/ oil catch can.. Custom ordered samco sport hoses and lines, just waiting for them to clear customs at jfk..
<3
Old May 12, 2011 | 02:48 AM
  #1594
any tips on preventing from paint getting on the raised part of the LNF valve cover so that my valve cover is yellow and so is lettering but the raised part will be black?
Old May 12, 2011 | 03:04 AM
  #1595
Glowbalt's Avatar
Old May 12, 2011 | 11:47 PM
  #1596
Arrow Painted or Polished "ECOTEC" letters on the valve cover:
Painted "ECOTEC" letters on the valve cover:
Remove the valve cover from the motor, Paint valve cover [wait atleast 2 hours to dry prior to tape], tape up the raised letters, use an exacto blade to cut out the tape with the letters under the tape, cover the remaining valve cover to paint the letters, let it dry for 2 hours, remove tape, then clear coat 3x or more to have a durable paint job, carefully replace the valve cover back to the motor and torque down the valve cover bolts to spec..
Painted "ECOTEC" valve cover with polished raised letters:
Remove the valve cover from the motor, Paint valve cover [wait atleast 2 hours to dry prior to tape], tape the letters 3x or use thick masking tape, then carefully use a 320grit orbital sander to remove the tape covering the raised letters [make sure the remaining tape between the letters isn't removed] until the tape and paint is removed from the letters on the valve cover, then use buffing/polish wheel, then buff to high shine [make sure not to remove the tape when using the buffing wheel], then clear coat 3x or more, carefully replace the valve cover back to the motor and torque down the valve cover bolts to spec....
Old May 13, 2011 | 02:08 AM
  #1597
ls1fbody's Avatar
Haz l33t wheelz.
Old May 13, 2011 | 03:36 AM
  #1598
DOMDOTCOM's Avatar
MADE STANCE COOL
Originally Posted by ls1fbody
i wonder who edited this..
dude i am so buzzin'
beer pong ftw
Old May 13, 2011 | 02:42 PM
  #1599
The editing makes it everything look too dark, but maybe its my screen
Old May 13, 2011 | 02:46 PM
  #1600
Edubs's Avatar
It is very high contrast, but I think that's intentional...
