Making Fog Lights Stay On With High Beams
Does anyone know if there is a trick to make the fog lights in my SS stay on when the high beams are on? I know you could do this in the J-body. Any help will be appriciated!
I don't remember seeing anything in the manual about that. The only way I think you could do it is to fin the head light switch power wire and tap into the foglight power wire. Maybe!
I remember in the J-bodies you could do something with the relay to make them stay on. You know how when you hit you highbeams you foglight so out? These are stock SS foglights.
Originally Posted by BlackSS/SC
I'm not worried if it's illegal or not. I live in Canada and the cops where I live don't pay attention to that.
Hope this helps
I've been in a couple cars (isuzu rodeo, dodge neon) where you could have both the high and low beams on at the same time, by balancing the high-beam toggle right in the middle of being on and off (ie, click once and it's high beams only, click and hold it for both beams, then position it just so, so it balances and keeps both on)
Not possible in my ss/sc but thought i'd throw it out there. anyone else notice this? anyone know if this high + fog would be bad on the battery or fusebox, or anything?
Originally Posted by l337m4573rpyr0
Step 1: Grab the knob on the end turn signal lever.
Step 2: Rotate said knob about 15 degress towards yourself
You will hear three chimes and your DIC will display "AUTO LIGHTS OFF"
Yep My SS/SC does this sometimes when I don't want it to. High/low and fogs all on at once. Its pretty bright but I never leave it like that. It can't be good for the switch and I don't feel like waiting for the dealer to change it........
OR turn the switch to parking lights and push the foglight button
BTW on a 2005 SS/SC you CAN turn the lights off while in motion
Originally Posted by Taro
Obviously you have not tried this otherwise you would realize you cannot turn the auto lights off when in motion.
Actually, I have (in a parking lot) and it works.
Originally Posted by 2006ArrivalBlueSS
Not to hijack your thread, but I was wondering if anyone has figured out how to defeat the auto light feature so that we can drive with just the ambers and fogs on at night.
In my car the autolight function can be turned off when I'm in motion. I usually use it when entering bases because the gate gaurds don't like being blinded when a car is pulling up to have their ID and tags checked.
have you tried?
i turn my DRL off every time im driving, i usually do it as im pulling out
i can turn them off and on when im in motion
