Making Fog Lights Stay On With High Beams
Old Apr 3, 2006 | 08:06 PM
HackAbuse's Avatar
Originally Posted by tiny
have you tried?
i turn my DRL off every time im driving, i usually do it as im pulling out
i can turn them off and on when im in motion
ditto
Old Apr 3, 2006 | 10:01 PM
hyperboimmv's Avatar
I remember the service manager saying something about the foglights being controlled by the 'auto lamp' body computer. I am not sure if there is a way to override this, except wiring a relay and using some diodes and hooking up to the highbeams. (the relay would be used to turn the fog lights off if needed.)
Old Apr 3, 2006 | 11:26 PM
Stealth06LT's Avatar
i like to screw around and just drive with my fogs on at nite when theres noone around on an empty road. the auto light function DEF can be turned off while driving.
Old Apr 3, 2006 | 11:33 PM
philco_3's Avatar
Proud Playstation 3 Owner
1) Fog light on while high beams. I think the trick with the J-Bodies was from the fuse box cut the wires and run new wires to the fog lights. I think anyway.
2)Autohead lights can be turned off while driving at night. I have done many times to screw around with friends. But you still have the amber lights on
Old Apr 5, 2006 | 01:25 AM
Actually, while driving, when you shut the autolamps off, by twisting the switch towards you (to off), it shuts everything off, even the dash lights. Thats how it is in the 05's anyways.
Old Apr 5, 2006 | 01:42 AM
b-spot's Avatar
Fog lights + high beams doesn't let you see as far as your eyes adjust to the bright near light of the fog lights and your distance of vision is actually less, even though it seems like you can see better with them.
brandon04
Oct 21, 2015 07:04 AM
DANRICKARD
Oct 1, 2015 12:08 AM
OPCrer
Sep 27, 2015 08:11 PM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
