Making Fog Lights Stay On With High Beams
I remember the service manager saying something about the foglights being controlled by the 'auto lamp' body computer. I am not sure if there is a way to override this, except wiring a relay and using some diodes and hooking up to the highbeams. (the relay would be used to turn the fog lights off if needed.)
1) Fog light on while high beams. I think the trick with the J-Bodies was from the fuse box cut the wires and run new wires to the fog lights. I think anyway.
2)Autohead lights can be turned off while driving at night. I have done many times to screw around with friends. But you still have the amber lights on
Fog lights + high beams doesn't let you see as far as your eyes adjust to the bright near light of the fog lights and your distance of vision is actually less, even though it seems like you can see better with them.
DANRICKARD
Oct 1, 2015 12:08 AM
