my driver side headlight
Old May 8, 2011 | 10:40 AM
chingajose's Avatar
well my retro driver side headlight is fogging up on the inside. what do i need to do for that to stop happening. if i have to reseal my headlight. what is the easiest way to reseal and stuff.
Old May 8, 2011 | 10:42 AM
TommyP's Avatar
AWD > FWD
Try putting them in the oven, then clamping them together with a clamp. That should create a better seal hopefully. If not, take them apart, clean all the glue out of the channels, and order some of this.
MyNismo.com - NISSAN OEM Sealer
it works fantastically.
Old May 8, 2011 | 10:45 AM
ericgt79's Avatar
^ that or this
Old May 8, 2011 | 01:09 PM
chingajose's Avatar
whats weird is there is no water on the bottom of the lense. it rained alot last nite and than it got damp. so today the mist on the headlight is going away but no water on the bottom of the lense. do i need to take the bulb and rubber seal off before putting the headlight in the oven. the degrees is 250 right? u think i am just going to do a reseal on it.
Old May 8, 2011 | 01:12 PM
TommyP's Avatar
AWD > FWD
ya take out the bulb, the rubber seal, and the turn signal and sidemarker bulbs and wiring. 215 is plenty of heat.
Old May 8, 2011 | 01:16 PM
chingajose's Avatar
ok cool. how long to stay in there. now the nissan sealer what is that? like a stripping or something? i appreciate the help fellas. i noticed mkulrey resealed the other headlight different when i got it back. there is no sealant on the outside it looks more like the factory headlights look like sealed.
Old May 8, 2011 | 01:19 PM
TommyP's Avatar
AWD > FWD
I just left them in for 5 min the first time, then reheat as needed. The nissan sealer is a rubber butyl strip. It's VERY soft, and you can easily stretch it even cold, to fill the glue channels. Then when you get plenty of sealant in there, press on the lens with a lot of force, put them in the oven, let them get warm, then clamp them together, and leave them clamped together until the headlights cool off.
Old May 8, 2011 | 01:27 PM
mkulrey13's Avatar
We sell OEM headlight sealent from TRS. PM us
Old May 8, 2011 | 01:29 PM
chingajose's Avatar
ok. i notice when u sealed the headlight that i sent u put the sealant on the inside and none of it is showing on top like the other headlight does.
Old May 8, 2011 | 01:36 PM
mkulrey13's Avatar
Ok we seal headlights up many different ways. 99% of leaks come from the back when there installed the rubber boot around the bulb area gets loose and does not make a seal.
Old May 8, 2011 | 01:40 PM
heathkidder's Avatar
i usually leave the oven door open also. but i would just put em in for alil bit and try the clamp or hold them together for a few min but if it that doesnt work its gettin fogged up from the bulb openin
Old May 8, 2011 | 03:20 PM
chingajose's Avatar
im thinking its the bulb opening. cause it rained alot and never saw any water on the bottom of the headlight. last nite it was damp and dewy out and it was fogged up a lil. there wasnt any water sitting on the bottom of the headlight housing.
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Tupp
Sep 30, 2015 08:18 PM
