My retrofit headlights and switchback turns
yes that was just halos, in person you can def see just the ring the picture blurred it so it just looks like a regular light. I ran it to a switched 12V. used a add a fuse tap and tapped the fuel injector fuse and hooked to positive wire on the halos to that so the halos are always on when the key is turned. and i rewired the parking light/turn signal connector so that they only turn on when either the fog lights are on, headlights/high beams are on and of course when i put the directional on. They are no longer used as a daytime running light. and of course they are white unless turn signal is engaged then they become amber.
roth
Sep 26, 2015 12:16 PM
