Need H.I.D's
Old Sep 17, 2009 | 12:04 PM
bluedevilss's Avatar
Need H.I.D's
I got these Projectors from Modern performance http://www.modernperformance.com/pro...lt-p-1724.html I need to get the H.I.D kit for them w/ h1 bulbs maybe 8K's and also for the stock foglights I Would info on an HID kit ... nee info and websites thanks
Old Sep 17, 2009 | 01:28 PM
Cobalt08LS's Avatar
get an h1 kit from 3bspec.com
Old Sep 17, 2009 | 01:43 PM
And is that kit with hi and lows and what about the foglights
Old Sep 17, 2009 | 02:50 PM
Cobalt08LS's Avatar
u need 1 hid kit for the low beams. an hid kit comes in a set of 2 one for each headlight.
high beams i wouldn't touch because it isn't great to put hids in a headlight that isnt projected because you can blind people. since only the low beam is projected. just use the bulbs for the high beams that modern performance supplied you.
Old Sep 17, 2009 | 03:22 PM
So do i get regular bulbs for the his that will give me that hyper white light?
And do those same kits work for the fog lights
Last edited by bluedevilss; Sep 17, 2009 at 03:22 PM. Reason: Automerged Doublepost
Old Sep 17, 2009 | 03:52 PM
TommyP's Avatar
AWD > FWD
When you buy an hid kit, you get 2 ballasts and 2 bulbs, one of each for each side of the car. If you buy the HIDs from 3bspec, they come with the relay harness in line that you will need so that you don't blow your wiring. As for the fog lights, you will need to buy a second full hid kit. This will need to be an H11 kit. You really don't need to get the hyper white lights for the highs. Just use the stock ones, they work O.K. and you really won't use your highs as much anymore anyway.
Cobalt08LS's Avatar
an hid kit comes with the bulbs ballast something to mount the ballast and all the wiring and harnesses needed.
if you want white id get 6000k
and hids will work for the fog lights
i just dont remember what bulb size it is
you will have to get another set for the fog lights
Old Sep 19, 2009 | 12:36 AM
DDMTuning.com look up the raptor kit. I wouldnt shop anywhere else for them.
Old Sep 19, 2009 | 01:04 AM
Floppin Nuts's Avatar
Are you guys pulling the DRL fuse? I don't see the need for running lamps when using the HID kit.
Old Sep 19, 2009 | 09:48 AM
yeah you better pull it or youll burn out your hids quick
Old Sep 22, 2009 | 10:55 AM
any one got pics of what the drl looks if i need to really pull that out
Old Sep 22, 2009 | 10:59 AM
Mr McCabe's Avatar
I hope you didn't pay that much for them!!
Also, go with 3B Spec, support our vendors! From past experiences stay the hell away from DDMtuning... yeah they are dirt cheap but you get what you pay for! They are garbage!
Old Sep 22, 2009 | 03:53 PM
lol speak for yourself, theyre deffinitly not
Old Sep 22, 2009 | 03:56 PM
wantedSS/TC's Avatar
yeah, I have DDM HID's and they're great!
Old Sep 22, 2009 | 07:42 PM
what he said - mine are badass
Old Sep 22, 2009 | 07:49 PM
SS/SC Crazer's Avatar
i went with VVME but i had to troubleshoot both the low beams and the fogs cause they didn't work at first! an they are made in china or some bullshit! DDMT sounds like a good deal with a lifetime warrenty, i don't know what anybody else has except VVME has a 14 month warrenty. i wouldn't get them again, they look good but never again! and by the way, 6K still has a rather blue tint to them. it sucks cause 4K has a yellow hue and 6K has a blue hue, there is no inbetween, so i would rather see a blue hue!
09Balt
Jul 9, 2010 02:35 PM
kenny5969
Feb 22, 2010 05:28 PM
07Maliboo
Jun 22, 2009 11:06 PM
jsac442
Jan 5, 2009 01:13 PM
