New E-brake
Old Aug 16, 2007 | 01:52 PM
  #51
lucky_lellow06's Avatar
Gorgeous! Looks stock. Should have been stock! I'm going to have to do this when I get a chance.
Old Aug 16, 2007 | 09:24 PM
  #52
xspyder85x's Avatar
im doing it, just got to find a niec ebrake that i like
Old Aug 19, 2007 | 08:58 PM
  #53
EvlPeanut's Avatar
Originally Posted by g5mike
Icemaid,I did the crappy tire ebrake mod and it turned out great,its so much easier to lift it up and down now is it not?
pics of your crappy tire ebrake mod???
Old Aug 19, 2007 | 09:10 PM
  #54
g5mike's Avatar
camera went to ****.I'll try within a few days,
Old Aug 20, 2007 | 11:17 AM
  #55
icemaid's Avatar
Good on Ya.....pics definately!!!, I would like to see what you got that fits. Did you have to cut off the inside piece, drill out the new handle or anything, did you get the boot from crappy tire also?????
Definately a nicer feel when using than the stock brick.
Old Nov 5, 2007 | 12:08 AM
  #56
Cobalt(312)'s Avatar
What year BMW convertible boot did you use?
Old Nov 5, 2007 | 12:21 AM
  #57
Greased's Avatar
damn i think this is my next mod... looks hot
Old Nov 14, 2007 | 10:53 AM
  #58
icemaid's Avatar
I think it was about an 03, Just wander the junk yard you should find something :-)
Old Nov 15, 2007 | 09:14 AM
  #59
Alright, I was just asking because i might just look for the aftermarket application for the 03 BMW roadster e-brake boot.
Thanks
Old Nov 18, 2007 | 06:41 PM
  #60
Silv3r's Avatar
Hey Mike where are those pics at? I wanna see the crappy tire version I don't feel like spending that much on an ebrake handle >.>
Old Mar 22, 2008 | 06:16 PM
  #61
Routs's Avatar
That looks really awesome, Icemaid, great job!
By the way, PM'ing you a question.
Old Aug 26, 2009 | 12:56 AM
  #62
XStylus's Avatar
Beautiful mod, Icemaid! Sorry for the necropost, but needed to ask:
Momo offers a 20cm, 27cm, and 35cm versions of that handle. Do you recall which one you used?
Old Aug 26, 2009 | 12:59 AM
  #63
jsscooby's Avatar
I want one.
curious too
Old Aug 31, 2009 | 04:16 PM
  #64
icemaid's Avatar
I don't remember what size it was, just picked it off the shelf and installed it, and it fit, didn't realise there were different sizes, sorry i cant help with that one.
Old Oct 29, 2009 | 06:54 PM
  #65
jlong3382's Avatar
Sub'd
Old Oct 30, 2009 | 01:41 AM
  #66
XStylus's Avatar
Gonna try this mod myself. Will post later after I'm done and let ya'll know how it goes.
Old Oct 30, 2009 | 09:30 PM
  #67
1cleang5's Avatar
that looks great.
Old Oct 30, 2009 | 10:31 PM
  #68
Dayta's Avatar
i deff gotta do that
Old Nov 26, 2009 | 09:06 PM
  #69
XStylus's Avatar
E-Brake handle installation instructions
Okay. Got it installed. It wasn't extremely hard, but I wouldn't call it a quick job since it required a bit of minor modification. I forgot to take pictures, but I'll try and describe what needs to be done step by step.
Items needed:
1) Short flat-blade screwdriver
2) A Dremel drill (sanding/cutting bits will be needed)
3) A Momo e-Brake handle (I used a Momo Pit Stop Steel) with removable rubber button hole/adapter.
4) E-Brake leather boot (I used a generic boot, but BMW boots can be found on ebay cheaply and are high quality)
Step 0) PLACE BRICKS UNDER THE TIRES OF YOUR CAR.
Step 1) Remove the panel under the parking brake. There's no screws holding it down, so just gently pull at the various edges until the tabs release so that it can be pulled out.
Step 2) Remove the brake handle. You will need a short flat-blade screwdriver to do this. Insert the screw-driver into the hole under the handle and twist until the tab releases, allowing you to pull the handle off.
Step 3) You should now have access to the handle skeleton. If you try inserting the Momo handle at this point, you will notice that there are some plastic guides/tabs that will prevent it from being inserted fully. These will need to be Dremelled off. I recommend dremelling off the long 4" plastic tab on the top, and also the lip on the left and right sides. When done, all sides should be flush. Note that I didn't dremel off the locking tab on the bottom so that I can put the "brick" handle back on in case I ever want to go back to stock.
Step 4) Slip your leather boot over the skeleton.
Step 5) Place the panel back on.
Step 6) Take the rubber button hole from your Momo handle and see if it fits with your e-brake release button. It should not be snug, it needs to be at least a little loose. If it is tight, you will need to use the dremel (or other tool of your choice) to enlarge the hole until it fits comfortably.
Step 7) Insert the rubber hole into your Momo handle and slide the handle onto the e-brake skeleton. Chances are it still will not fit properly. This is likely because the rubber hole is too long. Depending on which hole adapter you purchased or whichever one came with your Momo, you will need to shorten it. Remove it from the handle and use your dremel (or a hacksaw) to shorten as needed.
Step 8) When satisfied with fitment of hole and handle, insert the included hex screws into the tightening holes of the handle. Screw down the top first, then tighten left and right sides (I recommend not screwing in the bottom hole), checking carefully as you tighten to make sure that the handle remains positioned to your satisfaction.
The finished result:
Old Jan 23, 2010 | 06:39 PM
  #70
Billy Baldone's Avatar
Giving this a bump for all the people that just did the group buy from Redline and NGA.this is a great writeup.
Old Feb 20, 2010 | 07:03 PM
  #71
07ss_PJ's Avatar
What adapter do you need in order for this to fit properly or do you even need one at all? I noticed at least 7 different adapters for the MOMO pit stop handle. Anyone know? Thanks.
Old Feb 20, 2010 | 07:19 PM
  #72
JoshuaVnyrd1817's Avatar
To my knowledge you do not need one. Momo that is, at least the ones that were for sale in the GB.
Old Feb 22, 2010 | 02:16 PM
  #73
icemaid's Avatar
No adapter as far as i know, i never used one.
Old Feb 22, 2010 | 02:22 PM
  #74
07ss_PJ's Avatar
Grazie! Ordered the MOMO handle couple days ago. Excited to get it installed.
Old Feb 22, 2010 | 02:56 PM
  #75
Sweetsandman's Avatar
See RedLineGoods....they make top quality stuff...second to none..and the MOMO Handle from NGA.
