View Poll Results: Would you buy these headlights?
Voters: 323. You may not vote on this poll
New weird style projectors?
#753
Sorry for asking this it's already been answered but I really don't want to look through 42 pages. Lol.
Do these have DRL's? If so, what are they? What would be on if you turn on the parking lights? Thanks!
#755
#758
One of my cffl light bars is already burnt out. I don't care bout the bars or the leds but now it looks weird wit one bar out and the other workin. Anyone know how to disable just the bar, not the halos? I wanna disable the leds too. I hope the halos last a lot longer.
#760
so yeah....i got reall pissed off about these lights cause the stupid yellow reflector for the signal bulbs fell off......which caused me to baked the dam thing and take the fucken light apart...
as the for the cutoff......mine is absolutely fked up and as for the aiming....its absolutely fked up too....why?!! cause the aiming screw were all stripped.....second the internals of this is fked too...
oh my high beams are also FKED TOO....
why?! the projectors are mounted on this plastic which has the aiming screw BUT the highbeams are also attached to the plastic too.....so when u aim...u move the plastic which the projectors are mounted on...which also moves the high beams.... sorry i dont have any pictures but thats my 2 cents...
so even after this rant....im still using them....the cut/aiming is screwed up ....gonna put in hid and most likely will blind people...honestly im so bitter about these lights....but they got a hold on me!! so i must live with it....and suck it up...
oh if u check out my images...thats my messed up cut off...any help will be good!
#761
#765
#766
#768
this listing (160183202586) has been removed or is no longer available. Please make sure you entered the right item number.
If the listing was removed by eBay, consider it cancelled. Note: Listings that have ended more than 90 days ago will no longer appear on eBay.
#769
So since im UBERLY pissed off about my 2nd gen projectors....
im currently taking the dam thing apart....and modifying it myself....SUPER SUPER PISSED OFF....
whats gonna be different...
1) high beams are not gonna be adjusted (cause im gonna glued them!!) while aiming projectors...
2) More adjustable projectors...cause im gonna cut off the hovering mount which connects both high beam and projectors
3) hopefully if it works out...a nice clean TSX-type cut off...IF it works out.
pics will be up soon....im finish ranting.....for now.
#770
#771
look in this link for pics of the 2nd gen cutoff
https://www.cobaltss.net/forums/how-guide-43/how-install-aim-new-projectors-87215/
#772
nono its totally possible to get the tsx cut offs....i already took the lights apart and re-did the cut off shields....i got the cut off going....but just that these projectors are somewhat poor quality therefore light still leaks through...but im doing...gonna stick in hid tonights...will upload pics soon enough....a how-to mod 2gen CCFL
#774
bumpy bump..
a few Q's..
Anyone had issues with the light housing melting from the heat of turn signals? I've heard one bad story about it
Are the turn signal still 3157's?
Are the stock LED whites?
Could you do something to have only the halos as your DRL's and have 'em on all the time? (not the LEDs and corner lights though)
a few Q's..
#775
It is very likely the exact same projector from the other style light , for cost reasons ...nearly all aftermarket lamps have the same stuff in different styles .
The Black ones would actually look nice if they just had the halo's around the high and low beams....wow , cant believe I said that about a aftermarket headlight . The cold cathode tube and the 3 LEDs look worse than bad ...tacky **** right ther .
i want these head lights where can i get them?
Getaway_Driver
40
09-10-2015 09:11 AM
