newb question with shift knob
Old Jul 7, 2008 | 11:09 AM
pnoi604's Avatar
hey guys sorry stupid question, but not sure if im going to break something with my stock shift knob. anyways I was just driving the other day and all of a sudden it popped off. I tried putting it back on, but then it never went all the way down. I tried forcing it down further, but there still like 1/4 of in inch space in bettween the knob and the reverse trigger. anyway how can I get it in all the way without breaking anything??? thanks in advance guys!
Old Jul 7, 2008 | 11:14 AM
light'bolt's Avatar
do you have the spring that goes between the knob and the reverse trigger? If I remember right there should be a groove that the reverse trigger goes into the knob.
Old Jul 7, 2008 | 11:18 AM
ecotecon18s's Avatar
there should be a screw on top of the knob under the top gear pattern that holds it down
Old Jul 7, 2008 | 11:19 AM
EmperorJJ1's Avatar
ya theres a torx screw down there
Old Jul 8, 2008 | 10:08 AM
pnoi604's Avatar
Im not sure if im missing something but I don't see any screw underneath the top gear pattern. All I have is the spring the I put on the steel rod and the knob that has the hole underneath to put the rod in. =S
Old Jul 8, 2008 | 10:17 AM
the top plastic piece pops of (with the silver shift pattern on it) and a torx head screw goes under it to hold the shift knob down on top of the shaft. sound like your missing it
Old Jul 8, 2008 | 10:30 AM
pnoi604's Avatar
I guess I am missing it. Off to the dealer I go I guess, hope they don't charge me to get this fixed.
Old Jul 8, 2008 | 10:46 AM
Redline485's Avatar
they shouldnt charge you as this is a problem a lot of people have and there may be a tsb on this
Old Jul 8, 2008 | 10:48 AM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
You have a 05 or 06 dont you. Those shift knobs are pressed on. I think the 07s have a TORX screw.
Old Jul 8, 2008 | 10:55 AM
both of my 06s had torx screws in the top of them...
Old Jul 8, 2008 | 11:02 AM
da_kage's Avatar
I have an 05 and mine used to pop off all the time. There was NO screw holding it on, it was just pressed down. Take some contact cement put it on the shifter and pound the knob back on. I did that about 2 months ago and it hasn't popped off since.
Old Jul 8, 2008 | 12:22 PM
pnoi604's Avatar
Yea I have on 06 and didn't see any torx screw don't know if it could have gone missing though...
sounds like a good idea! but worried if it puund the knob too hard something might break...
Old Jul 8, 2008 | 12:33 PM
da_kage's Avatar
you'll be fine. just put some cement on it, take your fist and pound down on it a few times, works like a charm. you can't hit it hard enough to cause any damage.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
footballplaya3k
Sep 30, 2015 09:39 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
