Night Shading!
Nope, just washed them off really good and sprayed till i covered it all.
Waited ten or fifteen minutes, did it again, and repeated until they were really black.
Then I let them sit for like thirty/fourty five minutes and put a good layer of clear on.
Then when you lay it down on the outer circle, there should be a small indention that separates the reverse from the actual light.
Just get a pen, tweezers or a paper clip if you want to get it exact.
There's a ton of Cobalts shown here in our gallery... Check em out - http://www.taillighttinting.com/tintgallery.html
Or you could just tint the whole lens, and then remove the tint off the reverse light with a laquer thinner and q-tip or sand it off with a high grit wet sand paper(1500 or 2000). Thats what I did. Its much faster than taping it off and its much easier.
I just got painters tape and cut out small strips, so it's easier to bend.
Any more questions, let me know.
