No lights...
Old Jul 17, 2012 | 09:55 PM
cobythecobalt's Avatar
Angry No lights...
Last night I took out my speedo gauge and re-painted it, then put it back in. This morning I went to work and everything was working fine. then this evening i went out and the interior lights as well as the parking/turn signals didn't work. I checked the fuse and it was fine, i have no idea what it could be. does it have something to do with the speedo gauge? did i f*** something up?
Old Jul 17, 2012 | 10:08 PM
turbosmart4's Avatar
I would take everything apart again and re connect making sure it is connected properly... Thre could also b more fuses u could check
Old Jul 17, 2012 | 10:09 PM
K-Train04RL's Avatar
Check park lamp fuse
Old Jul 17, 2012 | 10:22 PM
Would the parking lamp fuse effect the interior lights too?
Old Jul 18, 2012 | 02:28 AM
Crav3's Avatar
I don't think it would but it be good to check.
Old Jul 18, 2012 | 02:31 AM
it actually does...there was a thread on this a week ago.
Sir_Hiro's Avatar
Parkin lamp fuse is ur problem...just happened to me
Old Jul 18, 2012 | 02:32 AM
this is the man to talk to
Old Jul 18, 2012 | 03:33 AM
Crav3's Avatar
Nice
the map lights on my rearview don't work tried new bulbs and checked all fuses. Could it be the mirror? Just asking since this problem is solved
Old Jul 18, 2012 | 04:12 AM
Sir_Hiro's Avatar
Its prob the mirrior..the parking lamp fuse does not affect the map lights...but to the OP you have to ask yourself why the fuse blew in the first place.
Old Jul 18, 2012 | 06:08 AM
awesome! thanks for the help. I'll check that after work and let you know if it was the problem
Old Jul 18, 2012 | 09:51 AM
Cobalt08LS's Avatar
blown parking light fuse will make running cluster AND hvac lights to NOT come on.
Old Jul 18, 2012 | 12:26 PM
Urban Rogue's Avatar
Ya its the park lamp fuse. ahd that issue once.
here is one for ya that is happening to me.
my information center on the cluster keeps going bright then dimming then bright etc...... but no other light on the cluster is doing this
Old Jul 18, 2012 | 01:02 PM
Cobalt08LS's Avatar
what cluster did you install?
SS? g5gt 140 cluster? one with LEDS?
Old Jul 18, 2012 | 01:30 PM
Me? my stock cluster
Old Jul 18, 2012 | 01:51 PM
Gelladuga69's Avatar
Mine does this for a second after my car switches from headlights to drl or vice versa.
Old Jul 18, 2012 | 02:36 PM
so you were right, it was the parking light fuse. but why would it do that randomly?
Old Jul 18, 2012 | 03:33 PM
check the wires around the tail lights. make sure there is no break in it.
mine was my own doing as I tapped that wire and then accidently yanked it and it touched metal blowing the fuse.
Old Jul 18, 2012 | 09:41 PM
Sir_Hiro's Avatar
Mine was when I put the stock sub back in I tightened a bundle of wires to the boddy of teh car to where it shorted.
TStone
May 29, 2014 11:44 PM
soundjunky
Oct 9, 2013 10:36 PM
operatic
3B Spec
Oct 2, 2010 12:27 AM
