No low beams! HELPS!
So I get out to my car tonight and turn the key and what do you know but I have no low beams! High beams work fine as do my running lights. I'm running Retrofit's with 5000k D2S bulbs. I checked the fuse box real fast and the low beam fuse is fine. I can also hear the relays clicking when I flick on my lows and high beans fire up fine. I just have no idea whats causing this since D2S bulbs only have low beams (high beams are just a moving solenoid that points the bulbs up a little) it means the bulbs are fine right? Any one have any idea whats going on?
