No more badges
Old Oct 9, 2010 | 01:59 PM
topsecretkush's Avatar
No more badges
Ok so i got the badges off but how do i get rid of the adhesive without damaging the paint?
Old Oct 9, 2010 | 03:12 PM
jdunn622's Avatar
i believe u can use googone, im pretty sure it wont harm the paint but just read the bottle to make sure
Old Oct 9, 2010 | 03:16 PM
Phyrric's Avatar
3m makes an adhesive remover that it the best option, I used a credit card and baking soda, it ******* sucked there is so much behind the rear bowtie
scotch89's Avatar
sounds sketchy but i used brake cleaner cause it takes for ever to get that stuff off. once u put some on hurry and try to get it off. after spraying it on grab water and poor some over the spot u sprayed so it dosent eat your clear coat.
Old Oct 9, 2010 | 04:48 PM
Ricer's Avatar
lacquer thinner, acetone, mineral spirits, goo gone.. and yes even brake cleaner.. will not hurt your clearcoat. Just be sure you use a soft cloth to wipe with.. a rough rag or paper towel or something like that could scratch your paint.. then wash and wax the area.. done!
Old Oct 9, 2010 | 04:56 PM
CoreySS07's Avatar
I went to NAPA a car parts store and bought a wheel for a drill thats made to take decals and pin strips off cars. it only cost 5$ and i still have over half if it left. Its like an eraser. Sorry I cant remember the name
Old Oct 9, 2010 | 05:28 PM
Bluelightning's Avatar
Got Bewst?
Use WD40. Dab it on the glue and let it sit for a few seconds. It will make the glue super soft and will wipe right off. It works great
Old Oct 9, 2010 | 06:07 PM
Malaclypse's Avatar
I use the edge of my thumb.
Won't scratch paint and if you roll it right, there will be little to no adhesive left on the car at all. The dirty outline can be cleaned with glass cleaner or denatured alcohol.
Yes you may get a blister but this method works and won't harm the paint.
Old Oct 9, 2010 | 08:07 PM
AndrewSS/TC's Avatar
Plus one, I use my thumb and a dab of goo-gone for the remaining outline, then nu-finish Polish over the area and can't even tell.
Old Oct 9, 2010 | 08:35 PM
troyss's Avatar
Use fishing string to cut of badge, use a hair dryer and get the sticky stuff hot and peel away double tape using your finger. Just push it and it will peel right up. Next their will be little amounts of tape left so use oops or goo gone. BEST WAY PEEIOD
Old Oct 9, 2010 | 10:26 PM
i used oops and a soft cloth it worked great ill put up pics later.
Old Oct 14, 2010 | 07:06 PM
cajunfive's Avatar
I used Turtle Wax bug and tar remover let it soak for 1 minute or so, wipe it off and then take a hair dryer, heat it up and use your thumb to take it off...VOILA'
Old Oct 14, 2010 | 11:18 PM
MyOtherSS's Avatar
medium reducer works well, any body supply store should have it.
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
riceburner
Sep 30, 2015 03:54 PM
Cptnslo
Sep 24, 2015 09:32 AM
Aug 29, 2015 03:11 PM
