Nut size.
You can take apart the entire car with a 10mm ratchet/wrench just about, jeeze. Even the damn headlight bracket bolts are 10mm.. wing bolts are 10mm.. Yessir, just a 10mm ratchet and you can play "Jiggsaw the Cobalt back together" with it.
Just in case there is any confusion here...
The socket size of the nut might be 10mm (I don't actually know, I'm just reading the thread), and the nut itself might be a 10-32, but the "10" in 10-32 has nothing to do with the 10mm socket. In fact, 10-32 is an english measurement.
if you haven't figured it out yet...you really should not be working on your car.if you cant take a socket set and try a socket on the nut till it fits then you should not be working on your car at all. is it really that compicated?
everyone has already told you what nut it is and your still asking..........read, fix , and be done with the problem
royce777
Sep 28, 2015 07:11 AM
