Ok. Im no maco painter so if..
Old Feb 17, 2008 | 02:55 PM
VibrantCOBALT's Avatar
I painted my trim and it turned out great. Now im in the middle of doing my glove box and the peice under the steering wheel.
What is the best thing to do if the paint turns out shitty, to get rid of it, and put a new one on.
Old Feb 17, 2008 | 03:01 PM
Sharpie's Avatar
Wipe it off with thinners, if it is still wet, if it is dry sand it off.
Old Feb 17, 2008 | 03:03 PM
ok thank you
Old Feb 17, 2008 | 05:26 PM
Switt23's Avatar
Or if you've already cleared it, you can wetsand it then rub it with paint thinner. Basically wetsand through the clear and then use the thinner and some forceful rubbing to rub it off.
Old Feb 18, 2008 | 02:02 AM
Bumblebalt's Avatar
okay i seen plenty of posts using the search to get the glove box off,someone give me a link or directions to getting the damn trunk release button off that little door on the panel under the steering wheel.
Old Feb 18, 2008 | 01:21 PM
Sharpie's Avatar
I am sure it just pulls out? One of the ways (i cant remember if it was towards you or away. But I know the trunk realease is very easy to take out. If I remember correctly there is like 2 tabs you have to push in and then it will slide out.
Old Feb 18, 2008 | 01:24 PM
there is 3 pins that u push and it should slide right out.
Old Feb 19, 2008 | 02:18 PM
Bumblebalt's Avatar
Thank you!
Rock on, thank you as well.
Last edited by Bumblebalt; Feb 19, 2008 at 02:18 PM. Reason: Automerged Doublepost
Old Feb 19, 2008 | 02:23 PM
neb07ss/sc's Avatar
may i ask what color are you painting your glovebox??
ThoR294
Oct 4, 2015 08:44 PM
Cptnslo
Sep 24, 2015 09:32 AM
memphisr24
Aug 13, 2006 12:41 PM
JCswoosher2
Jul 29, 2006 08:22 PM
My06Kobalt
Jul 11, 2006 06:18 PM
