Lots of Knock
Lots of Knock
Ok. I installed my new fuel injectors today. 42.5 lb lucas injectors. I have a 3 inch pulley with kn cai and magnaflow catback. My maf translator settings are those settings that are used with the intense stage 3 kit.
Maf Base: C
Maf WOT: 1
All of the little switches are set to the correct setting as well. Now, I have the aeroforce interceptor gauge and i'm reading knock. When I get on it past 4000 rpm, I get a LOT of knock. The gauge almost reads 10. Haven't pushed it to redline yet. Does anyone know why I am getting knock and how I can fix it?
Maf Base: C
Maf WOT: 1
right when I installed the injectors....I had the stock injectors in for 2 months, and would get most 2-3 degrees of knock at redline but only took it to redline like 4 times because I was running lean. The fuel injectors were maxing out. So now that i installed the new injectors, the freakin car is getting tramendous amounts of knock now. Feels A LOT fastaer but I don't want the knock. Would I be able to change that by playing with some settings on the Maf Translator?
whats the piston rods bearings etc hold up to power wise as in are you pushing too much power for the pistons rods etc and if you not pushing enouh how close are you? u could be slowley wearing them down or it could be a fuel problem
So does anyone know how to fix my problem? I put 93 octane in my car all the time. Would running lean cause knock? Maybe I can richen up the fuel flow with the maf translator
dude, i know whats happening to your car. Your MAF tables are all F'ed up because of your intake. You need to get that car dyno-tunes asap before you blow it up... i was just at Intense and was seeing the same thing. If you put the stock airbox on, it should get a lot better.
Your MAF tables are all messed up, thus your not getting the right amount of fuel.
My car has a few more mods then you do, but i was running a 14.4:1 AFR on the dyno because the intake was messing everything up really bad... and keep in mind this was with Intense's Stage 3 PCM tune...
My car ran just fine, but lean as hell under WOT. Get on a dyno, or get a wideband and start tuning that thing.
I am seeing between 1-2.8 on my aeroforce gauge for knock, how do you gauge degrees of knock? all engines develope some knock, but whats the safe/unsafe limitations?
At what point does the LSJ begin the retard timing due to knock?
Originally Posted by memphisr24
All because of my stupid K&N? What about if I switch my MAF WOT setting to 2? Could that help it out? And possibly set the Maf Base to like B to richen it up.
Thank you for your advice. I would have not known what the heck was going on if it wasn't for you guys. My gauge stopped working so I can't read my knock anymore
, I richened the WOT setting to 2 (which is 4% richer) but haven't touched the base yet. I will in like 5 minutes. Once cobalt-addiction gets the hang of tuning, i'm getting a tune from them (since they are a lot closer to me then Intense is, 8 hours closer lol). If I get my gauge working tonight and it still shows knock even with WOT setting to 2 and Base setting to B or A, i'm taking off my intake tomorrow and putting back the stocker on.
Would cutting off the airbox on the stock intake mess it up in any way? Because I still want the loud whine but I don't want the car to be running like crap.
If you dont get the gage working, to where you can monitor stuff, i would put the stock airbox back on the car untill you can get it tuned. The MAF sensor is insane sensitive... so modifying the stock airbox could ulter the its reading, but im not sure to be honest w/ you.
Be carefull, no WOT pulls unless you really know whats going on.
Keep in mind rich is always better then lean... Black smoke from exhaust means your rich, and not gonna blow things up.
Put the stock airbox back on and see....also you can always try an octane booster and see if it quiets down. also there is a possibility of the knock sensor being installed too tight and having it read ghost knock ....
I can tell you, the highest i've seen was 7, i know I said 10, but just rounded it, I have hit 7 and it doesn't pull timing yet.
I think I might go back to stock if I can't fix this problem
So you had the pulley on with your stock injectors?? You just added the larger injectors and this started? If so sounds like a issue with 1 or more of the injectors. The larger injectors should put out more fuel at the same psi of the stock injectors. Also yes lean will cause knock, so you need to be very careful. Truly if your gauge is not working I would ot be making any pulls (unless you know how to hear knock)
