Outside Door Handle
Old Jan 19, 2013 | 10:29 AM
Play Pat's Avatar
Outside Door Handle
I'm pretty sure there is a thread of this but I can't find it.
My door handle outside of the car popped off, this happened to my driver side door but I had the dealership fix it when I was covered.
How do I fix this myself?
mostly the whole handle comes off and you can see in side the door.
Old Jan 21, 2013 | 12:08 AM
Play Pat's Avatar
60 views and nothing?
Old Jan 21, 2013 | 12:10 AM
Idk take the door apart and see what broke then replace the broken part
Panels pretty much pop and lift up&out to get off
sent from my craptastic galaxy s2!
Old Jan 22, 2013 | 09:52 AM
Cobalt08LS's Avatar
take the door panel off. and look in where the post to the lock is. theres a little black grommet that goes around it. remove that and shine a flash light in there. theres a bolt in there i think 10mm. one thats directly straight and one which is to the left. the bolt to the left i believe you can stick a straight socket in one of those holes and can loosen the bolt that way. undo those and the door handle pops right out. i changed one to a sedan before.
http://www.g5club.net/howto/dnw/pw12.JPG
right below that foam square remove that little gromett
GaryGibblez
Jan 14, 2020 10:35 AM
hhrfreek
Jun 4, 2016 11:25 PM
chefhhr
Oct 26, 2015 10:36 PM
patooyee
Oct 15, 2015 05:11 PM
