Paint over Plastidip??
not too bad as in i took some plasti dip and sprayed one coat over, let it dry and hit it with 2 coats of clear and bam all done.
these are some pics that you guys wanted. It may not look too shiny in the second pic cause they were a little dirt brake dust haha but in the sun light and all cleaned up they look great. if its nice tomorrow ill wash my car and get some better pics i get compliments on them all the time because people always say isnt plasti dip not shiny and i say yeah i just put clear coat over it lol
what clear coat did you use ?? I think Imma try that instead of painting..Its bad that I like the way the wheels look when there wet then when there clean and dry haha
i used the krylon fusion clear or you can use the dupli color (color match clear coat) also works really good. Make sure when you do the plasti dip you get nice smooth coats and not rough because then it wont look nice and shiny and do the same with the clear coat nice smooth coats but be sure to not put too much on at once or it will run i always use a hair dryer to help the process, if you have any other questions let me know.
I used wheel cleaner when I did it which may be the prob lol and I dont really care if it wont come off easy..They will stay black most likely but thanks for the heads up
ive had mine on since feb. going to be taking it off tomorrow because my wheels are getting polished...ill let you guys know what removal method i use and how hard it is to take off lol have 5 dip coats and 4 glossifier coats. more than likely using that aircraft remover stuff
If you just have plastidip on your wheels they will peel off no problem. I've had mine plastidipped two different colors now, once with glossifier and once without and they both peeled the same.
This video should answer alot of questions. These guys have been doing plastidip for a long time and have pretty much tried it all.
Myths About Plasti Dip (Vol 1) - YouTube
[URL="http://sphotos-
