Painted Headlights.....
Old Mar 19, 2006 | 03:53 PM
Xenozx's Avatar
Originally Posted by Mercury
Jeremy, next time I am down visiting my girlfriend in newark, I'll call you up and we can paint them lights. It Should only take us about an hour.
Awesome!
Old Mar 19, 2006 | 04:00 PM
HackAbuse's Avatar
Originally Posted by trent_ky
I really like it! My oven will not go down as low as 100. 175 is the lowest temp it will let me set it on. Also, how do you get the headlights out of the car? What did you cover the yellow turn signal section up with?
He left the amber lens in and painted over it
Old Mar 19, 2006 | 04:31 PM
trent_ky's Avatar
Theres not something over the amber in this picture?
https://www.cobaltss.net/gallery/fil...7/100_1072.JPG
Old Mar 19, 2006 | 04:36 PM
HackAbuse's Avatar
yeah, its called SPRAY PAINT
Old Mar 19, 2006 | 06:10 PM
Doc's Avatar
Doc
Is the side marker a reflector..??
I'm thinking you could get away with not having it show if you replaced the bulb with a yellow one....
Old Mar 19, 2006 | 06:13 PM
djpatrick35's Avatar
Very nice, very nice. I'm too chicken to try any of that stuff with my car, but nice how-to
Old Mar 19, 2006 | 10:21 PM
wikkymaster's Avatar
nice job, looks awesome, you did everything exactly the way i did it, same corner lights, same painting procedures! very nice, except mine are leaking after being on for a few months now, give it time they probably will leak ive even redone them
Old Mar 19, 2006 | 11:50 PM
theBLUEone's Avatar
I think you will be fine at 175 degrees just don't leave the headlamp assembly in the oven for 20 min... Start with 10 min. and see if you can get it apart if not go for a few more...Just keep an eye on it....
It is our side marker for the front end of our cars so it is a reflector as well...BUT you do not want to take it out and leave it out, it will be ugly....It's not the reflector that looks bad, it is the amber plastic IMO....
Gotta take a chance sometimes....
Don't tell me that....I hope not...What sealant did you use? Try removing all th sealants and start with some fresh sealant/adhesive...
Thanks again everyone!
Old Mar 20, 2006 | 12:39 AM
Cobalt30's Avatar
the blue one.. so when you painted the headlight you keep the circuler amaber lense in place then poped it out after they were done painting to keep the paint out of the chrome shinny area in their? and hows it pop out?
Old Mar 20, 2006 | 12:52 AM
theBLUEone's Avatar
Correct....The amber lens has 2 tabs that you just press a small screw driver in and pop it out....It's easier to do than explain... Once you have the headlamp apart then you will see...
Old Mar 20, 2006 | 01:57 PM
  #36
hardtocope's Avatar
nice lights, they are sharp on the black car.. how are your lights at night? any moisture problems yet?
Old Mar 20, 2006 | 02:54 PM
  #37
Brenn8402's Avatar
in new york we can have white instead of yellow in the front, thats what they told me last time i got pulled over in oswego for blue lights in the front...
Old Mar 20, 2006 | 03:35 PM
  #38
HackAbuse's Avatar
Can someone confirm this?
Old Mar 20, 2006 | 03:38 PM
  #39
Mercury's Avatar
Mark, now all you need is a projector in each head lamp!
Old Mar 20, 2006 | 03:43 PM
  #40
memphisr24's Avatar
For the people who disassembled their headlights, are you guys having any condensation or fogging happening in the headlight housing or no?
Old Mar 20, 2006 | 03:49 PM
  #41
Mercury's Avatar
Fogging can be avoided by using a plastic polish on the inside lens as well as using new sealant to reseal the lamps.
  #42
theBLUEone's Avatar
Yea, I definitly do....Now, if I can figure out how to do it then I would!
I have not condensation problems yet...
The light output has not changed at all...
Old Mar 20, 2006 | 05:45 PM
  #43
Dragonsfire12345's Avatar
what adhesive did you use whats it named? I plan on doing this tomorrow
Old Mar 20, 2006 | 07:49 PM
  #44
Badmunky's Avatar
The cobalt looks so hot with black headlights. I have no clue why GM made them the way they did.
I used 3M Windsheald sealer to do mine. No leaks here.
Get a heat gun. It makes it about 100x easer!
Later
Old Mar 20, 2006 | 08:20 PM
  #45
Coblt ss super's Avatar
wouldnt the plastic melt in the oven? and the turn signals u had the superstar lights but then u had amber?
Old Mar 20, 2006 | 09:07 PM
  #46
trent_ky's Avatar
I want to do my headlights like that but I'm afraid i will f**k something up and that they will leak.
Old Nov 15, 2006 | 12:40 AM
  #47
alright I got the headlights taken apart.... question how the hell do you take the reflector and amber cover off the signal light
Old Nov 15, 2006 | 01:21 AM
  #48
c'mon anyone
Old Nov 15, 2006 | 01:56 AM
  #49
senior_brown's Avatar
excellent write up, i've been meaning to do this, even before i seen it like that on the factory headlights on the new vettes
Old Nov 15, 2006 | 02:04 AM
  #50
g5mike's Avatar
painted lights rule
