Painting the upper dash
I just got done painting my pillars and im looking into painting the headliner and dash black. I want the dash to be a smooth gloss black. As you may know the dash is not smooth and in debating if i want to sand it or bondo it. It was a pain in the ass to sand the pillars and the dash is a much larger area. Am i wasting my time with the bondo or should i man up and just sand it all? I know im going to have to sand the bondo anyway, but it will be much easier than sanding hard plastic.
i wouldnt unless u do a flat color the glare u will get from the sun will murder ur eyes
but if u must the way to do it is 4 wet coats of filler primer wet sand smooth then paint
thats the way i did my center console
don't cover it with bondo.. chances are it will eventualy crack or somthing. Sand as much of the texture off then apply a few coats of adhesion promoter, followed by enough layers of filler/high build primer to make it smooth. then paint on that.
If you want a smooth gloss finish, similar to the outside of the car you will need to remove the dash board from the car and fiberglass it. Its a big chore. Like someone already said the glare will kill you plus is shows every single finger print, smudge, and speck of dust. Its a pain for an everyday car.
I have done fiberglass work before and for this situation it would be pointless. fiberglass is for structure and the dash has that already, Plus you have to bondo over the fiberglass anyway. Technically i could do, but it would be more work than needed.
Here is an update, I got the entire dash out and sanded. Its starting to look pretty good. My problem now is the passenger airbag cover. Is there any way to get that off? My dash will look like **** if everything is painted except for the airbag cover.
Not yet, everything is over in my moms garage. Im getting my head shaved today for St. Baldricks then im going back over there. I will get some pics then. Do you know what part im talking about tho?
DO NOT USE bondo over top your dash. i already experimented with bondo on our panels. itll start to sand down nicely, then when you get to where you want it, it'll just crack off. just go borrow sombodys DA sander and go to town. its the eaisiest way to get it smoothed out, did it to the door panels and it looks like a dream. just my advice on it.
I got tied up yesterday and didn't get a chance to take pics. I was looking at the headliner and it is turning out awesome. The dash comes apart in two pieces. The piece closest to the wind shield has a coat of black on it and is lookin SHINEY. The main part of the dash is still primered beacuse im still trying to get some of the rough spots smooth. If i get a chance i will go over this week and take pics but more than likley it will be this weekend. Anyone know how to get the passenger side airbag cover off?
It is hard to explain. The cover has plastic brackets that are supposed to break away when the airbag explodes. They are held down under these metal hooks that are attached to the airbag. I could cut the plastic to get the top off but i dont wanna affect the airbag or have it rattle after it is finished.
